Flash Form and Navigation Button Issue (DoFSCommand)
Jul 20, 2007 10:20 AM
In short, How can I get a <cfinput type="button" to send out a javascript command to change the current page location.
I have this code:
When I click on the HTML type button, the relocation happens as expected.
When I click on the equivalent cfform button, it does not.
I'm guessing it is something in the syntax of the onClick event, but I have to say I'm lost. Flash MX documentation says this should work right (?)
Cheers,
    Aug 9, 2007 11:14 AM   in reply to bryn50
    In relation to communication issues between Flash and Javascript: I am trying to get Javascript to talk to my Flash form, but I can't get it to work.
    I would like at least to be able to change the value of a hidden field in my form, or even better to execute an actionscript function, from Javascript.
    I believe the answer lies somewhere around the ExternalInterface.addCallback function, but I just can't get it to work.
    I am trying to do this because I have a flash form with a tab navigator and the showing tab is bound to a hidden field.So far so good...I am now trying to use the new CF8 CFmenu functionality to control which tab shows. That's why I need it!
    Any guidance appreciated! Thanks a lot!
    Alain
    Aug 9, 2007 3:32 PM   in reply to bryn50
    Hi, and thanks +++ for your reply and the code... I can't get it to work either, it drives me mad...
    I wish asfusion would get their teeth on it, they are just the best! Unfortunately, they are not much into flash forms these days, just flex...
    Will keep you posted - and everyone else! - if I can get it to work!
    Alain
    Oct 25, 2011 2:15 AM   in reply to Alain Levy-s3SmK8
    hi,
       i have the same problem also...on how to communicate normal button to cfinput button. Did you find out how to solve this?
    Pls let me know.   Many thanks,
    I just want to click the button of cfform flash using a normal button outside.
    Jeff
