nateyboy044
Is actionscript processed sequential (line by line)?
Jul 18, 2007 2:26 PM
Ok, so long story short, I have a loop that fills three different arrays. As soon as the loop finishes, on the next line, a function is called that loads dynamic images into movie clips. However, this isn't working as I thought. Instead, the function is being called at the same time as the loop is running. Therefor, the first few images don't show up and I get undefined errors. However, if I delay the function being called by 50ms, I don't get the error. This means that it is a timing problem and that flash is executing the loop and the function call at the same time.
Does anybody have any experience/advice on what or why this might be happening?
Thanks in advance.
Edit: Also, my entire movie is implemented using actionscript in the first frame of the movie.
    Jul 18, 2007 2:47 PM   in reply to nateyboy044
    have you tried waiting one frame? maybe you have objects or movie clips that need to initialise first?
    just a thought
    can you explain in more detail what the loop and the function do?
    Jul 18, 2007 3:12 PM   in reply to nateyboy044
    Actionscript is handled in a top down fashion (typically) and for non-function encased code, is called as soon as that particular section of AS is loaded into the player. If you need to delay the call to this function, use a setInterval or Timer (depending on AS version). Just remember to clear the interval or timer after you are finished with it.
  • kglad
    Jul 21, 2002
    Jul 18, 2007 3:24 PM   in reply to nateyboy044
    most actionscript is executed sequentially (or synchronously), but some is asynchronous. one of the most common places to encounter asynchronous events is load event..
    Jul 18, 2007 7:40 PM   in reply to nateyboy044
    With things like this is is generally good to show your code. You describe what you think is happening, but perhaps it isn't what you think.
    Nov 15, 2007 12:23 AM   in reply to nateyboy044
    I've a question that could be similar to this:
    Let's say I want to make an object wiggle horizontally using a function(),
    function Wiggle(){
    object._x++;
    object._x--;
    However, the object doesn't move at all.
    My idea is to make the object move a pixel right and then left when the function is executed. Is it possible to execute the code line by line rather than "tabulating" the result?
    Nov 15, 2007 6:34 AM   in reply to nateyboy044
    function Wiggle(){
    object._x++;
    object._x--;
    It does both actually. You're just not seeing it because of how Flash
    works - the function happens in between frame cycles, so the object moves
    forward a pixel, then back a pixel, then the frame is redrawn - so the
    object does not appear to move. You can fix by doing one or the other,
    dependent on a simple flag:
    var flag = 0;
    function Wiggle(){
    flag++;
    if(flag % 2){
    object._x++;
    }else{
    object._x--;
    everytime you call wiggle you increment flag. If it's now an even number
    increment x, otherwise decrement.
    HTH
    Dave -
    Head Developer
    http://www.blurredistinction.com
    Adobe Community Expert
    http://www.adobe.com/communities/experts/
    Nov 16, 2007 12:51 AM   in reply to nateyboy044
    Got it...thanks!
