dont know if this helps guys but this is the page code from
my black screen............
<html xmlns="
http://www.w3.org/1999/xhtml"
xml:lang="en" lang="en">
<head>
<meta http-equiv="Content-Type" content="text/html;
charset=iso-8859-1" />
<meta name="description" content="kuler from Adobe Labs.
Quickly create harmonious color themes online. Explore, create and
share color themes." />
<title>kuler</title>
<script type="text/javascript"
src="kuler/scripts/browserDetect.js"></script>
src="kuler/scripts/swfobject.js"></script>
src="kuler/scripts/swfaddress.js"></script>
src="kuler/scripts/AC_OETags.js"></script>
<script type="text/javascript" >
var flashVersion = '9.0.115.0';
</script>
<link rel="stylesheet" type="text/css"
href="kuler/scripts/home.css" media="screen" />
</head>
<body >
<div id="container">
<div id = 'flashcontent'>
kuler requires the latest version of the Adobe Flash Player.
<br/><br/>
<a href=http://www.adobe.com/go/getflash/><img
border="0" width="88" height="31"
src="kuler/images/get_flash_player.gif" alt="get flash
player"/></a>
<br/><br/><br/><br/><br/>
</div>
<div id="footer">
<a href="
http://del.icio.us/post"
onclick="window.open('
http://del.icio.us/post?v=4&noui&jump=close&url='+encodeURIComponent(l ocation.href)+'&title='+encodeURIComponent(document.title),
'delicious','toolbar=no,width=700,height=400'); return false;"
title="save to del.icio.us"><img
src="kuler/images/delicious.small.gif" alt="save to del.icio.us"
border="0" width="10" height="10"></a>
<a href="
http://kuler.adobe.com/links/kuler_help.html"
target="_blank">help</a>
<a href="
http://www.adobe.com/cfusion/webforums/forum/categories.cfm?forumid=72 &catid=622"
target="_blank">kuler talk</a>
<a href="
http://www.adobe.com/misc/privacy.html"
target="_blank">privacy policy</a>
<a href="
http://kuler.adobe.com/links/kuler_terms_of_use.html"
target="_blank">terms of use (updated 8/06/07)</a>
</div>
</div>
<!-- Flash detection script -->
<script type="text/javascript">
// <![CDATA[
//KulerServices_WWW1
var v = GetSwfVer();
var versionArr = stringArrayToNumber(v.split('.'));
var requestedVersionArr =
stringArrayToNumber(flashVersion.split('.'));
//Windows express install works fine
if (isWin || BrowserDetect.OS == 'Mac') {
var so = new SWFObject('kuler_20071011.swf', 'kuler',
'1001', '712', flashVersion, '#161616');
so.useExpressInstall('kulerExpressInstall.swf');
so.addParam('menu', 'false');
so.addParam('allowScriptAccess', 'sameDomain');
so.addParam('devicefont', 'false');
so.addParam('swfliveconnect', 'true');
so.write('flashcontent');
//But if we're on a Mac, the Flash installer fails, so show
an HTML link to Get Flash
} else if (versionArr[0] >= requestedVersionArr[0]
&& versionArr[1] >= requestedVersionArr[1] &&
versionArr[2] >= requestedVersionArr[2]) {
function stringArrayToNumber(p_array) {
this.arr = [];
for (i=0;i<p_array.length;i++) {
this.arr.push(parseInt(p_array
return this.arr;
</script>
<script language="JavaScript" src="
http://www.adobe.com/uber/js/omniture_s_code.js"
type="text/javascript"></script>
<script language="JavaScript" type="text/javascript">
// <![CDATA[
//Need to uncomment one or the other based on the
environment
var s_accountName="mxmacromedia,mxkuler"; // Omniture Report
Suite ID
var s_pageName = "";
var s_channel = "Kuler";
var s_wd=window,s_tm=new Date;if(s_code!=' '){s_code=s_dc(
s_accountName);if(s_code)document.write(s_code)}else
document.write('<im'+'g src="
http://192.168.112.2O7.net/b/ss/'+s_accountName+'/1/F.3-fb/s'+s_tm.get Time()+'?[AQB
+'&pageName='+escape(s_wd.s_pageName?s_wd.s_pageName:(s_wd.pageName?s _wd.pageName:''))
+'&server='+escape(s_wd.s_server?s_wd.s_server:(s_wd.server?s_wd.serv er:''))
+'&ch='+escape(s_wd.s_channel?s_wd.s_channel:(s_wd.channel?s_wd.chann el:''))
+'&[AQE]" height="1" width="1" border="0" alt="" />')
function sendAnalyticsEvent(str) {
s_pageName = str;
var ns=s_accountName;
//if(str!=null) ns+=","+str;
//alert("ns=" + ns + "; str="+str);
void(s_gs(ns));
function setChannel(str) {
s_channel = str;
</script>
<!--/DO NOT REMOVE/-->
<!-- End SiteCatalyst code version: G.6. -->
</body>
</html>
