UDP messages with a router
Feb 8, 2008 11:47 AM
Hey all,
I've written a test movie to check the viability of running a MUS app on a server behind both a standard router and a firewall. Sadly, my attempts have failed - the TCP messages are being forwarded just fine, yet the USP messages are being stopped dead in their tracks at the firewall.
I'm convinced my port forwarding is the reason - sadly, Director's poor documentation doesn't specifically say the port range it uses, only the "starting" port being 1627 for UDP. I've tried port forwarding 1626 (TCP) all the way up to 1647 with no luck so far.
From searching on this newsgroup I get the feeling that people have been able to get this working. Can anyone provide some insight on this?
Thanks in advance.
    Feb 10, 2008 5:57 AM   in reply to Zen Seven
    In this case all you need is that number from the documentation.
    If you're using port 1626 and using UDP then you need to set up your port forwarding to also include UDP. I work for a large ISP providing advanced technical support for various sized businesses, and I deal with port forwarding daily... if you have any questions then ask away :-). Btw, what's the brand and model of router?
    Feb 12, 2008 4:43 PM   in reply to Zen Seven
    try setting your pc up in the DMZ... go to 'Applications & Gaming' and select the submenu 'DMZ' and set in the ip then click 'enable' and lastly, 'Save Settings' button.... if the DMZ doesn't work for you then something is definitely wrong. You can also use an online port scanner site like http://www.t1shopper.com/tools/port-scanner/ to test the ports, but I don't currently have any programs listening on any ports so I cannot test and don't remember if any of the online scanners will list/test UDP and TCP or only TCP.
    Oh, just to let you know, the DMZ basically forwards all ports to your computer, essentially negating the firewall in your router so putting a computer in the DMZ is a good test to see if the problem isn't somewhere else... btw, do you have a firewall running on your computer?... you could be having an issue there... disable Windows Firewall or any other firewall you may be running.
    Feb 13, 2008 4:37 PM   in reply to Zen Seven
    > uses, only the
    That's because it doesn't use a range. For each connection, a new udp socket
    will be created, and it will be bound to the first available port >= udp
    starting port.
    As for your tests, are you performing them from within the NAT? If so, then
    your udp messages will most probably fail - would be a bit lengthy to
    explain the reason, but has to do with the smus / mu protocol design.
    "Zen Seven" <webforumsuser@macromedia.com> wrote in message
    news:foibk6$352$1@forums.macromedia.com...
    > Hey all,
    > have
    > messages
    > all
    > able
    > Thanks in advance.
    Feb 13, 2008 6:04 PM   in reply to Newsgroup_User
    > The opposite has been occurring ...
    Open your multiuser.cfg file.
    Locate the
    UDPServerAddress = xxx:port
    is xxx the external ip (or name) of your server?
    news:fp06q6$dcq$1@forums.macromedia.com...
    quote:
    > socket
    > starting port.
    > then
    > The opposite has been occurring - tests from within the NAT have worked
    > fine
    > (connecting to the server via the local IP) while any attempt at
    > connection to
    > the router IP, within the NAT or not, UDP wouldn't work. Which make sense
    > to
    > me, since there isn't any sort of port forwarding required to get the
    > packets
    > across.
    Feb 13, 2008 8:58 PM   in reply to Newsgroup_User
    > I've analyzed my outgoing UDP packets from my client program and for some
    > crazy reason
    That's what I meant by "design" in my last post.
    During the logon sequence, and if UDP messaging is enabled, the server sends
    a message containing the udp address that the clients will use.
    If you are behind a NAT, and since there is no way to tell the server your
    true ip, then the clients will be sending udp messages to invalid
    addresses - to the server's NAT address that is.
    So, there seems to be no solution for enabling udp behind NAT.
    Or at least, not when using the original MUS.
    If interested, you can download:
    http://xtrema.rtr.gr/beta/Xtrema.Net.857.rar
    The package contains:
    - a simple serverless LAN chat movie (udp, broadcast)
    - a network tools movie (ping, tracert, lookup, wakeup etc.)
    - a MUS emulator movie
    - the Xtra on which the movies are based.
    Notes:
    - this is the first, and therefore lightly tested, Xtra build that
    uses overlapped IO and completion ports (the best that NT has to offer) for
    stream communication.
    - the mus movie is evolving along with the Xtra, so several commented blocks
    of code may exist in it. Ignore such lines of code..
    - if you browse the mus movie scripts, you'll most probably get answers to
    various mus related questions you may have.
    http://xtrema.rtr.gr/xtrema.htm
    news:fp0bn4$i9h$1@forums.macromedia.com...
    > Locate the
    > I've had it set to both 0.0.0.0:1627 and the local ip. Setting it to the
    > external address (the router address) gives me an error on start up of
    > MUS:
    > "Problems with using UDP on this IP address:" and then nothing can
    > connect.
    > crazy reason the destination IP is the local IP of the server, and not of
    > the
    > router! How it got that information is the question - I guess MUS sent a
    > "this
    > is the IP you should UDP to" or something even though I explicitly connect
    > to
    > the router ip?
