quote:
Originally posted by: Newsgroup User
That's because it doesn't use a range. For each connection, a new udp socket
will be created, and it will be bound to the first available port >= udp
starting port.
As for your tests, are you performing them from within the NAT? If so, then
your udp messages will most probably fail - would be a bit lengthy to
explain the reason, but has to do with the smus / mu protocol design.
> socket
> starting port.
> then
> The opposite has been occurring ...
Open your multiuser.cfg file.
Locate the
UDPServerAddress = xxx:port
is xxx the external ip (or name) of your server?
> Locate the
