Hello,
On my CF8 web host, I sometimes get strange java.lang.nullpointerexceptions errors. All my code works flawless since the year 2000. The same pages do work but sometimes, maybe 1 out of 30 try's, the error appears again. First I thought it was a session problem or a problem with Application.cfm. But I stripped those down and it even happens with simple queries. I think it has to do with queries or MySQL 5.
Has anyone encountered this error? The system says "The system has attempted to use an undefined value, which usually indicates a programming error, either in your code or some system code." But I have all my values defined and it is not a programming error. It is more like a server configuration error I guess.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Null Pointers are another name for undefined values.
500
ROOT CAUSE:
java.lang.NullPointerException
at com.mysql.jdbc.Statement.setMaxRows(Statement.java:2178)
at coldfusion.server.j2ee.sql.JRunStatement.setMaxRows(JRunStatement.jav a:214)
at coldfusion.sql.Executive.executeQuery(Executive.java:1229)
at coldfusion.sql.Executive.executeQuery(Executive.java:1008)
at coldfusion.sql.Executive.executeQuery(Executive.java:939)
at coldfusion.sql.SqlImpl.execute(SqlImpl.java:325)
at coldfusion.tagext.sql.QueryTag.executeQuery(QueryTag.java:831)
at coldfusion.tagext.sql.QueryTag.doEndTag(QueryTag.java:521)
at cfhetkoor2ecfm251397670.runPage(E:\westlandkoorconcordia.nl\wwwroot\h etkoor.cfm:1)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:192)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:366)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279 )
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.ja va:48)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePers istenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:175)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:8 9)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringS ervletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46 )
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java: 284)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java: 543)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.ja va:203)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPoo l.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.j ava:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool. java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
javax.servlet.ServletException: ROOT CAUSE:
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringS ervletFilter.java:70)
The system has attempted to use an undefined value, which usually indicates a programming error, either in your code or some system code. Text
500
ROOT CAUSE:
Latest reply:
Ultimatorx, Feb 1, 2012 10:13 AM
