Simon Bailey
Inability to install AIR applications on mac os x
Apr 22, 2008 2:53 PM
To say this is a frustration is an under statement :) I have recently just bought a mac pro and installed the AIR runtime no problem. However, when I try and install and AIR application, whether downloaded from a site or one of mine created from Flex I am presented with the following error:
quote:
Sorry, an error has occured The application could not be installed because the AIR file is damaged. Try obtaining a new AIR file from the application author
I have tried with mulitple applications i.e. Adobe Media Player, Twhirl etc to no avail. I have uninstalled, restarted, installed, restarted, installed prior Beta versions, upgraded, quit most 3rd party software applications in case of conflicts.... all fail.
I am using mac os x Version 10.5.2 on a mac 2 x 2,8ghz quad core intel xeon.
Help pls, I have to write an article on AIR for a mag and am not keen on using the 'ol slow mo laptop ;)
Simon
    Adobe Employee
    Apr 22, 2008 4:17 PM
    Please capture a log file as described at http://blogs.adobe.com/simplicity/2007/10/air_installer_logging.html.
    thanks,
    Oliver Goldman | Adobe AIR Engineering
    Community Member
    May 7, 2008 9:28 AM
    I have the same problem. I saw the error when I tried to install an AIR app which is already installed on the system before. If I remove the app on my system and use the install badge, I can install it fine.
    I've found out that if I set <customUpdateUI> to false and my install badge works again. I am trying to find a way to fix it so I can use both custom update UI and the install badge together.
    Any suggestion?
    quote:
    Starting app install of http://www.raysquare.com/test.air
    UI SWF load is complete
    UI initialized
    Downloading file to /private/var/folders/A8/A8JNeb-ZESiThFev5neT7++++TI/TemporaryItems/Fl ashTmp0
    Received HTTP Response Status event
    Response URL is http://www.raysquare.com/test.air
    Waiting for user confirmation
    User confirmed action: install
    Converting to /private/var/folders/A8/A8JNeb-ZESiThFev5neT7++++TI/TemporaryItems/Fl ashTmp1
    Conversion is complete
    AIR file is bound to version 1.0
    app id C6DBEEA1-D1F2-4291-9AC5-CF629633C3FA
    application is bound to this version of the runtime
    Application is installed? true
    Application handles updates; launching it
    Failed while converting AIR file: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2004" errorID=2004]
    Starting cleanup
    Installation exited
    Raymond
    Community Member
    May 9, 2008 9:56 AM
    Some of my customers are getting the same problem. Is anyone from Adobe even concerned about this? I've got about 20 people with the same problem, mostly on Macs but some on PCs too.
    Here's one logfile:
    Starting app install of file:///Users/<me>/Desktop/EarthBrowser.3.0.1.air
    UI initialized
    Converting to /private/var/tmp/folders.14651219/TemporaryItems/FlashTmp0
    Failed while converting AIR file: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="internal crypto error" errorID=0]
    Starting cleanup
    Installation exited
    Adobe? "Internal Crypto Error"? Anyone?
    Adobe Employee
    May 9, 2008 10:58 AM
    Concerned, yes, but still unable to reproduce this.
    Can anyone confirm this error is occurring on Windows? A log file file from a failing Windows install would be appreciated.
    thanks,
    Adobe Employee
    May 12, 2008 10:20 AM
    Thanks for your effort in trying to narrow this down; the additional information you've provided is helpful. We're working on it.
    Adobe Employee
    May 12, 2008 4:13 PM
    Please try the following two experiments, if possible, and let us know the results.
    1) Attempt to install an AIR application while off-line.
    2) Delete the folder ~/Library/Application Support/Adobe/AIR/CRLCache and then try installing again.
    thanks,
    Community Member
    May 14, 2008 1:40 PM
    Hi Pickle Jar,
    we have tried to repro your issue via transplanting the users to a different drive. Unfortunately, we were still unable to repro your issue.
    Since the problem is following your user account, can you try the following?
    1: create a new user account and move it to the other drive to confirm that you do not see the problem with the new account.
    2: if that is the case, it will appear that there is something in your home that the AIR application installer is incompatible with - we can try to narrow that down further
    3: you said that you repaired your disk for permissions problems -> can you also run Keychain and perform first aid on the Keychain while logged into the account that is giving you problems?
    Nobuo
    Adobe Employee
    May 20, 2008 12:38 PM
    Simon:
    We've tried to reproduce this with relocated user folders, per your post on 5/14, again with no luck.
    It's possible there's a conflict from php, mySQL, etc. If you could narrow it down to the specific product there's a conflict with then we can try to reproduce that issue. Is that something you can try?
    Our other option is to try debugging this further on your machine, if that's ok with you. If you could send me a private message, we can talk about how to go about arranging that.
    thanks,
    Oliver Goldman
    Community Member
    May 23, 2008 6:47 AM
    I wanted to jump in here and say that I am having the same issue. AIR runtime installs just fine. Every application I try to install, though, gives the "the air file is damaged" error message.
    I've tried everything mentioned in this thread (deleting the AIR directories, different user accounts, reinstalling, etc, plus rebooting multiple times. No joy.
    What's interesting is absolutely no problems on my Mac Pro Desktop, but can't get anything to work on my Mac Book Pro laptop. Both are Intel machines. The MacBook Pro is an early model with a CoreDuo processor, but I don't see why that would make a difference.
    This is really frustrating.
    Community Member
    May 23, 2008 10:59 AM
    AIR install logs if these reveal anything:
    Starting app install of file:///Users/dave/Downloads/twhirl-0.8.1.air
    UI initialized
    bubbles=false cancelable=false eventPhase=2 text="Unhandled exception
    Error: Error #2014" errorID=2014]
    Installation exited
    Starting app install of file:///Users/dave/Downloads/SpazAIR.air
    UI initialized
    Installation exited
    Adobe Employee
    Jun 2, 2008 5:42 PM
    Just curious. Do people who have trouble installing AIR applications also have MobyDock? We have received reports that MobyDock causes failures in AIR application installations. Please disable MobyDock if you ahve it installed and retry installing your AIR application again.
    Jose
    Community Member
    Jun 3, 2008 9:16 AM
    I've never heard of Moby Dock, so no, I don't have it installed.
    I had hoped 10.5.3 update would resolve my problems, but it did not.
    Community Member
    Jun 4, 2008 9:34 AM
    Same problem so I'm watching this thread. I get "The application could not be installed because the AIR file is damaged. Try obtaining a new AIR file from the application author." Running OX 10.5.3 on G5. No Mobydoc. Tried suggestions you've listed no luck.
    I was able to manually install AIR, but can't get AIR apps including the new Pandora app.
    Adobe Employee
    Jun 4, 2008 10:26 AM
    @chrisdat: This same dialog appears for a number of different specific errors. You should capture a log file of the failing application install to determine the precise cause. It may be an issue with a known resolution.
    Community Member
    Jun 4, 2008 10:36 AM
    Since AIR files are really just zip files (I think)...is there a way to manually install them?
    I've kind of given up on the AIR apps I wanted, but I fear that AIR may become more popular and it will start becoming an issue.
    Community Member
    Jun 4, 2008 11:59 PM
    Hey Oliver. I know this is a bit of a non-sequiter, but I'd just like to thank you for participating in the forums. It totally gives everyone a 'warm fuzzy' that AIR engineers are looking in to see if there are any bugs.
    Again, thx. I know it's time-consuming and frustrating communicating with us sometimes, but it's greatly appreciated.
    Community Member
    Jun 23, 2008 4:21 PM
    I am having the same problem as pickle jar on my mac os x 10.4.11. I cannot seem to make anything work. I have tried reinstalling, changing permissions on the folders and Installer. Not sure if I can work with AIR now. Will try it on Ubuntu later, but I really wanted to see it on MAC.
    Here is my install log:
    Performing runtime install
    UI initialized
    starting user confirmation
    Installation type: new
    starting elevated install
    subinstaller: starting install
    subinstaller: Scheduling runtime installation operations
    subinstaller: Beginning runtime installation
    subinstaller: Beginning install
    subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
    subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
    subinstaller: Saving /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer$
    subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installe$
    subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Install$
    subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app
    subinstaller: Saving /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/Frameworks
    subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/tmp/folders.501/$
    subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/Frameworks
    subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app to /A$
    subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
    subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
    subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
    subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
    subinstaller: Execution complete; beginning commit phase
    subinstaller: Deleting /private/var/tmp/folders.501/TemporaryItems/FlashTmp0/file1
    subinstaller: Deleting /private/var/tmp/folders.501/TemporaryItems/FlashTmp0/file2
    subinstaller: Commit complete
    subinstaller: install complete
    AND my appinstall.log
    tarting app install of file:///Users/alexiicarey/workspace/AIR/To_Do_List/TodoList.air
    UI initialized
    Unpackaging to /private/var/tmp/folders.501/TemporaryItems/FlashTmp0
    failed while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="invalid package signature" errorID=5022]
    starting cleanup of temporary files
    application installer exiting
    Any help in this area would be relieving. Thank you
    Community Member
    The error I get is when I try to run an .air application in the AIR installer. It says :
    Sorry, an error has occured The application could not be installed because the AIR file is damaged. Try obtaining a new AIR file from the application author.
    Thanks.
    Adobe Employee
    Jun 23, 2008 4:39 PM
    @Alexii: Your log file actually indicates a different problem from the one pickle jar is encountering. In your case, you appear to be trying to install an invalid AIR file. Do you have this problem with all AIR files? Or only this one?
    Community Member
    Jul 15, 2008 10:02 AM
    I had the same issue with the crypto error message. After deleting all certificates from the Login keychain it started working. I am suspecting it might be caused by a self signed personal or CA certificate. I did not play with it further but I am pretty sure I could track it down to the offending cert.
    Adobe Employee
    Jul 15, 2008 11:35 AM
    @stjohnsj: Thanks for the info. That's consistent with the failure, and would also explain why we haven't been able to reproduce it. If you could narrow this down to a specific cert and make it available that would be much appreciated.
    Community Member
    Jul 16, 2008 1:14 AM
    I found the offending certificate. It was added to my keychain by Apple Mail simply because I had received a digitally signed email from a person using this certificate some time ago. That explains why the issue is so random with a lot of users. Please contact me so that I can email the cert to you directly.
    Community Member
    Jul 16, 2008 7:03 AM
    Have you guys made any progress in figuring out why some can't install any application and only get the "air file is damaged" issue?
    The air files aren't damaged, the exact same file installs flawlessly on my desktop, but not a single app will install on my laptop, as indicated in previous posts.
    Adobe Employee
    Jul 16, 2008 9:40 AM
    @dsa01: We've made progress on some issues and not on others, as this thread makes clear. Note that the "AIR file is damaged" message is somewhat generic, and appears when a number of different individual errors occur.
    The error message you encountered and posted above is from an earlier release of AIR. If you could re-try with AIR 1.1, we can take another look at the particular issue on your machine.
    Community Member
    Jul 16, 2008 10:00 AM
    Yes, I tried with Air 1.1 this morning before posting here. Same message. I tried with Spaz and Twirhl packages. "air file is damaged" message on both programs, freshly downloaded this morning.
    What do you suggest I try at this point. Was about ready to write off AIR altogether until my RSS feed showed some life in this topic again the last two days.
    Community Member
    Jul 16, 2008 10:20 AM
    I too thought there was no progress. I installed 1.1 this morning. It seemingly installed fine. But when I tried Adobe Media, or Earth Browser Air apps - I get the Air file is damaged message still. Below is my log file:
    Starting app install of file:///Users/christinedattilo/Desktop/EarthBrowser.3.0.4.air
    UI initialized
    Unpackaging to /private/var/folders/9c/9c2l9zRf2RWQ1++BYv7eNU+++TM/TemporaryItems/Fl ashTmp0
    failed while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="internal crypto error" errorID=0]
    Thanks for taking a look - I'd love to use Air - Chris
    Adobe Employee
    Jul 16, 2008 10:27 AM
    @dsa01: We'll need a current install log from your machine to make any more progress on your particular case.
    @chrisdat: Per stjohnsj's comments above, this is sometimes caused by an invalid certificate in Keychain. I recommend exploring that option. Please let us know what you find.
    Community Member
    Jul 16, 2008 11:01 AM
    I deleted all keychain login certificates. I rebooted. I tried Adobe Media again, didn't work. Here is my log:
    Starting app install of file:///Users/christinedattilo/Desktop/adobe_media_player.air
    UI initialized
    Chris
    Community Member
    Jul 16, 2008 11:04 AM
    How do I capture an install log? The link in the first or second post of this thread that gives instructions is dead.
    Thanks.
    Community Member
    Jul 16, 2008 11:09 AM
    Community Member
    Jul 16, 2008 11:45 AM
    quote:
    Originally posted by: chrisdat
    Link to how to capture install log:
    http://kb.adobe.com/selfservice/viewContent.do?externalId=kb403123&sli ceId=1
    Thanks. Here's the log for SPAZ:
    Starting app install of http://funkatron.com/apps/spaz/AIR/SpazAIR.air
    UI initialized
    failed while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Error #2014" errorID=2014]
    Community Member
    Jul 20, 2008 8:05 AM
    I was getting the same problems as pickle jar, I am on a MacBook running OS 10.5.4. I backed up the /var/folder/zz folder then removed it. Now AIR apps will install. I am not sure what is held in this folder, I hope someone can enlighten me.
    Community Member
    Jul 20, 2008 8:37 AM
    deleting the /var/folders/zz folder did not fix this issue for me. I can't even get Air installer to install properly any more. Launching the AIR app used to install it into the /Applications/Utilities folder, and associate .air files with it, now nothing happens when opening the program from the dmg file.
    Trying to install anything from the web fails as well. A couple of more install logs:
    UI initialized
    stateRunningAppInstaller: appinstaller -runtime "/var/folders/CO/COLPFwJZGACYWWjy3XA3NE+++TI/-Tmp-/airraEOLk/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=9,0,124,0 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://funkatron.com/apps/spaz/AIR/SpazAIR.air -- "installed from web"
    App installer failed; exit code 7
    begin quitting
    Community Member
    Jul 21, 2008 2:30 AM
    Oliver: Are you interested in getting the crypto error causing certificate file? If so then contact me directly as I don't want to post someone else's certificate publicly. The problem with the cert is real and 100% reproducible. If the cert is in the keychain, AIR apps won't install. If you delete it, everything works ok.
    Adobe Employee
    Jul 22, 2008 12:43 PM
    quote:
    Hi stjohnsj,
    Oliver is on vacation right now. I have sent you a private message. Could you send the information to me?
    This will help us to track down the problem.
    -ted
    Community Member
    Jul 22, 2008 10:31 PM
    I don't have certificates and still can't install air applications.. really is frustrating ! :-(
    Hope you find a solution and update soon.
1 2 Previous Next
Actions
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
