vivekvijayan
Flex live Video Encoding
May 1, 2008 6:09 AM
Hai.
I am developing a video chat application in flex. Can anbody help me in the video encoding part?
I need the video to be encoded using ON2VP6 or H264 to get a better quality. How it can be done live using flex?
VivekVijayan
    May 1, 2008 6:56 AM   in reply to vivekvijayan
    Actually flex is not a video encoder you have to use for instance:
    Flash Media Server.
    Or if you want something for free you could use:
    FFMPEG
    http://ffmpeg.mplayerhq.hu
    I hope this would help you.
    May 2, 2008 10:15 AM   in reply to vivekvijayan
    Actually the encoder it's just a service so if you upload a file to a folder and the encoder service is running it'll automacally encode your files, so there you can develop some logic in your web app server to integrate this proccess with Flex.
    May 2, 2008 11:14 AM   in reply to vivekvijayan
    If you are doing Video Chat you will almost certainly need to integrate with Flash Media Server($ for large numbers of simultaneous streams) or Red5 (FOSS). They do the streaming video stuff you need. FFMPEG or MPlayer MENCODER is more for creating progressive videos I believe (unless that is what Red5 uses under the covers).
    Dec 16, 2010 11:16 PM   in reply to slaingod
    The problem is, you need a clientside technique to encode the video-chat-stream with a useable codec, cause the client/user have to upload this video(chat)-stream to the server, mostly with a small user bandwidth.
    Actually flash supports only this standard codec for encoding the user video input, wich requires a high bandwith and represents still a real bad quality.
    Thats a bad fact for adobe, cause this should be natural for such an "media software/system".
    Anyway, someone has a solution for encoding the clients webcam input with a common codec before streaming to the media-server?
