latomgirl
Help Printing--Wants Output File
May 20, 2008 11:37 AM
Hi, When I go to print, I get the same normal print menu to print to my default printer, and then when I press OK, another menu comes up entiteld: Print to File. It then says: Output File Name: and then has where you need to type in the file name. If I cancel, then it won't print. If I write a name in, it then another box called: Progress, and bars quickly appear and finish. Where it goes, I have no idea, but not to my printer. How can I get rid of this? Thank you so much.
    May 28, 2008 10:13 PM   in reply to latomgirl
    I am having the same issue and have tried everything, I think it is a registry problem but I don't know.
    May 28, 2008 10:32 PM   in reply to latomgirl
    I did figure it out, you have to deselect the check box in the printer menu that says "print to file" it is near the bottom left of the dialogue box. Let me know if you need more help.
    Oct 22, 2008 3:32 PM   in reply to latomgirl
    This is really good topic
    Jan 31, 2010 11:14 AM   in reply to custom_guards
    Thank You    SO much, we needed to know this that we have been trying to figure out for so long. It was easy peasy! Thank you so  much!
    Jul 19, 2010 1:11 PM   in reply to latomgirl
    Eu também tenho o mesmo problema, será que tem a ver com o registro?
    Brasi, SP
    Telelista - Lista telefonica online do brasil
    Sep 27, 2011 6:32 AM   in reply to latomgirl
    I find this information very useful and it has considerably saved my time.thanks
    Delhi Escorts
    Sep 28, 2011 8:57 AM   in reply to latomgirl
    I'm having the same problem and this doesn't fix it. I've tried both with the Print to file checked and not checked! Any other suggestions?
    Apr 2, 2012 1:39 AM   in reply to latomgirl
    thanks for proper reply
    Apr 9, 2012 4:01 PM   in reply to Nick\'sNana
    Check the port of the Adobe PDF printer and be sure it is set to PDF Port (or something like that) and not File. If you print with the print-to-file selected and open that file in Distiller to get a PDF, do you find success? If so, then check that AcroTray is running in the background.
