Hallo,
now I and my colleagues have the same problem - but the trick with starting RoboHelp for Word didn't word. When I try the way about "File/Batch" and select "printed documentation" on the dialog, I got the message "Word VBA Macro version registered is incorrect. Please reinstall Printed Documentation."
We are using RoboHelp HTML 7, Windows Vista and MS Word 2007
See Print Issues on my site. It covers various problems with Word.
Hallo Peter, it seems that your site is broken. When I try to select a topic from Menu, I got the "Couldn't find page"-message (i.e. http://www.grainge.org/menu/pages/authoring/printing/printing.htm). Best regards oeri
If I select from the menu, I get the right page and it does not include "menu" in the path.
What browser are you using? It works in FF and IE7.
Please try again.
I tried IE7 and FF - with the same result. But the link in the main-text of your home page "authoring" is working and from there I found a way to http://www.grainge.org/pages/authoring/printing/print_issues.htm#word_ issues without using the javascript-menu...
But back to the problem: none of the tipps worked. I think it is a registry related issue. I also tried to start RoboHelp for Word with administrator rights but it made no difference. To bee complete I also started RoboHelp HTML and Word with admin rights. It still didn't work.
Hi all
Peter, the broken link is pointing to:
The actual page seems to be at:
http://www.grainge.org/pages/authoring/printing/printing.htm
Comparison:
Not sure where the "menu" bit crept in. ![]()
Cheers... Rick ![]()
Rick
I know. When you select from the menu, is it working for you? It does for me so I cannot work out how anyone would get a path with menu in it.
<Was RH installed with admin rights?>
We are a big company and we use an automatic installation tool (Netinstall). One person is installing the product (with admin-rights) and the tool logged all what happened on the machine. Then the colleagues can install the product with only one click. Normally this works fine... With RoboHelp we used the original .msi installation.
I will try to reinstall the product directly
<Is your profile on your hard disk?>
My profile is on a network drive (roaming profile).
On the installation I was going to refer you to Item 19 on http://www.grainge.org/pages/authoring/rh7/using_rh7.htm but now that you have done a direct install, I think that anything there is ruled out.
In any event, I think the problem is related to your profile being network based. I don't know enough about the details of that to guide you other than being pretty sure that is the problem. Hopefull someone else can come in on this or a search will find something.
I think, but am not sure, it is the fact that your Normal template and the RH templates are not on the local drive.
I've got it! As you assume, Peter, is has to do with the roaming profile. The RoboHelp templates were in the roaming profile (C:\Users\xxx\AppData\Roaming\Microsoft\Templates - where xxx ist my user name) but in Word they were not activ. I could activate them in Word (in Word-Options / Add-Ins / Manage ... go to) but when I restart Word, they were inactive again.
Now I changed in Word-Options/Extended/General button "path for files" the path for "user templates" and "startup" to directories outside the roaming profile (i.e. c:\robohelp\startup). I copied the RoboHelp Templates (PrintDoc.dot, Style Mapping.dot and RoboHook.wll) to the new "startup"-directory. I started Word and now the RoboHelp templates were active!
ThenI started RoboHelp HTML and tried to generate printed documentation - and now it worked
For a short time I could see a message like "waiting for register VBA macros". I think that was the most important thing. But I don't know what happend in the background (couldn't find anything in the registry) Now I changed the path back to my originally roaming profile-directories - and the "printed documentation" still works!
Best wishes
Olaf
P.S.:
I use the German version of Word 2007, so maybe my translations are not correct - sorry
| German (what I saw) | my translation |
| Word-Optionen | Word-Options |
| Add-Ins | Add-Ins |
| Verwalten ... Gehe zu | Manage ... go to |
| Erweitert | Extended |
| Allgemein | General |
| Dateispeicherorte | Path for Files |
| Benutzervorlagen | user templates |
| AutoStart | Startup |
I believe, in other cases the start of "RoboHelp for Word" did the same thing - register the VBA macros - Don't know, why it didn't worked in my case
Oeri:
So if I have got it correctly the steps were:
1] Copy the RH templates to a temporary local folder.
2] In Word, point the User templates to that folder.
3] Run RH and the "waiting to register VBA macros message will run.
4] In Word, point the User templates back to the original folder.
One thing I would suggest is renaming the folder in [2] to see if things still work. Otherwise it could be that RH is still relying on those templates rather than the ones Word has registered.
Perhaps you could try that and post back, thanks.
Works for me! I had problems after I installed RoboHelp 8 on my computer last year and FINALLY I can print from RH. I was so frustrated. Does anyone have the problem of the following message that displays 3 or so times when compiling the printed documentation?
Do I need to change something else? I didn't write down what the originals paths were...my bad...can anyone tell me where the default paths were pointing to?
Thank you!
Sorry but not one I have seen or heard of.
RoboHelp 8 supports up to and including Word 2007.
What problem were you having before you followed the steps in this thread?
I was able to eventually produce RH Printed Doc on Win/Word 7 with the method of creating a temporary folder for the RH templates and directing Word to it. It didn’t work the first couple of times I tried, possibly because I didn’t save the Word file after changing the User templates path. But that was a couple of days after the first attempts, so don’t know if it was something else.
A team member was unable to make it work until I helped her enable macros in Word.
Thanks for your contributions to the problem resolution Peter and all.
Mike
