okeah1
Full Screen problem
Feb 1, 2008 7:19 AM
I was able to play movies before in a full screen mode, but recently it started freezing video content when I click on open to fuul screen icon. I reinstalled 9.0.115.0 player and reinstalled activeX, still no help. Maybe I should install an older player? If yes, where do I find an older version?
    Feb 29, 2008 2:47 AM   in reply to okeah1
    I have the same problem, runnig Vista business. It has been previouly working, but probably after a Windows update or for an unknown reason, the full screen mode is not working. the player is working but in fullscreen I get only the sound, the screen is either black or grey, but no video. I tried to uninstall, reinstall with the administrator account, but it's still not working.
    Waiting for a fix either from Adobe or Microsoft.
    Added later: ------> My friends there is a simple fix:
    - on the video, right click.
    - select settings
    - click the tab Display (little painting brush)
    - UNCHECK : enable hardware acceleration.
    Now it works. : ;-))
    Mar 2, 2008 5:46 AM   in reply to okeah1
    When I installed 9.0.115.0 approximately 3 weeks ago, I discovered that I could no longer access videos in full screen. I therefore used System Restore to return to a date prior to installing this version. Everything worked normally but in the last few days IE continually crased. I have now installed 9.0.115.0 again, and have lost my full screen capability again. I have been advised to ditch Adobe in favour of another program, but would have thought Adobe could have sorted this out by now. I am also surprised there are not more replies to this thread!
    Mar 13, 2008 4:03 PM   in reply to Dancville
    I'm also having this issue, Vista Business Flash 9 R115. I'm beginning to get tired of waiting for a fix, this is extremely frustrating.
    Mar 14, 2008 12:17 AM   in reply to Jensonb
    Same here I having the same problem since I update to version 9.0.115 I can not put it to full screen, I can hear the sound but no picture specially when watching you tube video and other flash video. I hope adobe resolve this problem this a Bug they need to attend to.
    Mar 18, 2008 2:41 PM   in reply to okeah1
    any update how to fix the problem?
    Mar 18, 2008 2:48 PM   in reply to okeah1
    Same problem here, already made a thread on it.
    http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=4 4&catid=184&threadid=1345446&enterthread=y
    There is a workaround posted by me in there.
    Mar 22, 2008 10:02 AM   in reply to okeah1
    Dear Okeah:
    I have the same problem with full screen mode. It worked fine until I installed the latest version of flash. Now it is gray or greenish. the sound works but the scree in blank (gray or greenish)
    Did you find anything out?
    thanks
    May 16, 2008 1:15 PM   in reply to okeah1
    I am %99 sure this is not about OS because i was getting same error on Ubuntu.When i tried to downgrade to flash player it worked like a charm
    May 17, 2008 1:42 AM   in reply to gent44
    I think its a problem with the player and its compatibility with the service packs rather than the Os itself.
    May 20, 2008 7:24 AM   in reply to mykelala01
    There is a simple fix:
    - select settings
    Now it should work. : ;-))
    Jun 3, 2008 8:41 PM   in reply to okeah1
    I have the same problem, runnig XP pro :/
    Jun 5, 2008 7:35 AM   in reply to okeah1
    i think it is to do with the OS and compatibility
    Jun 10, 2008 12:37 PM   in reply to degrangier
    Thank you that works! But the esc button does not return me to small screen and I have to use contr-alt- del to get back. An ideas?
    Tenor62
    Jun 10, 2008 1:01 PM   in reply to okeah1
    Its really strange but I was having the sane problem and was getting so flustrated I considered paying someone to look over my system but first I used system restore to roll back to a working setting which was okay for about a week but then we came across the same issue again. Ive done a clean install of xp and installed the latest player and its fine now making me think there is a conflict there.
    Jun 12, 2008 1:05 PM   in reply to okeah1
    16. ,
    Jun 12, 2008 2:26 PM   in reply to okeah1
    Jun 12, 2008 2:34 PM   in reply to okeah1
    Thank you that works! But the esc button does not return me to small screen and I have to use contr-alt- del to get back. An ideas???
    18. ,
    Jun 12, 2008 2:39 PM   in reply to okeah1
    I am %100 sure this is not about OS because i was getting same error on Ubuntu.When i tried to downgrade to flash player it worked like a charm
    Jun 12, 2008 3:42 PM   in reply to okeah1
    Jun 12, 2008 3:43 PM   in reply to okeah1
    Jun 15, 2008 5:04 AM   in reply to degrangier
    I founded myself the fix:
    - select settings
    Jul 14, 2008 7:53 AM   in reply to okeah1
    step1: Install it with Macromedia MX.
    or
    Low your security level in IE.
    Jul 20, 2008 11:27 PM   in reply to okeah1
    try some adobe supported sites, they have have old flash player.
    but did you update your OS. it may work fine.
    Jul 21, 2008 3:21 AM   in reply to okeah1
    this is not OS issue. i wonder, some thing else is missing.
