Windows error 193 during install
May 17, 2008 3:14 PM
After LaunchAnywhere finishes preparing to install I get an error headed LaunchAnywhere Error which says "Windows error 193 occured while loading the Java VM". I have verified the size of the downloaded CF file and all seems correct. I also seem to have the latest JAVA version installed. Any suggestions on what I should try next?
Running on Win XP Home SP 2 on an AMD 64 Athlon X2
    Jun 17, 2008 4:25 PM   in reply to krluck
    Same exact thing happened to me today trying a trial of cf. Ugh. Any answers?
    Jun 18, 2008 6:17 AM   in reply to coleo
    krluck wrote:
    > No answers so far.
    > I assume others have managed to install CF 801?
    I just upgraded to 801 yesterday, is that the same? Or are you talking
    about a clean, new install of 801.
    Anyway I experienced no errors, problems or difficulties at all.
    Answered the questions, clicked the buttons, and viola upgraded
    ColdFusion server.
    Jul 17, 2008 11:43 AM   in reply to krluck
    Please try checking to ensure the following:
    - you have sufficient drive space for the install of CF and Java VM
    - you have downloaded the proper installer (ie. installing 64 bit windows version on 32 bit XP Pro will fail).
    Sep 10, 2008 3:11 AM   in reply to krluck
    I had the same problem - I know it sounds obvious but the first place I checked was the installer icon properties which claimed the instal had been blocked - there was an option to unblock and I tried the instal again, more success the LaunchAnywhere process seemed to complete %100 - then the box reopened "Wndows Error 193 occured while loading the Java VM" I also run a 64bit compatibility and latest Java check - no problems. I'm sure I have enough diskspace. The CF is the 801 btw.
