quote:
Sorry, an error has occured The application could not be installed because the AIR file is damaged. Try obtaining a new AIR file from the application author
quote:need
Failed while converting AIR file: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="internal crypto error" errorID=0]
quote:
Starting app install of http://www.raysquare.com/test.air
UI SWF load is complete
UI initialized
Downloading file to /private/var/folders/A8/A8JNeb-ZESiThFev5neT7++++TI/TemporaryItems/Fl ashTmp0
Received HTTP Response Status event
Response URL is http://www.raysquare.com/test.air
Waiting for user confirmation
User confirmed action: install
Converting to /private/var/folders/A8/A8JNeb-ZESiThFev5neT7++++TI/TemporaryItems/Fl ashTmp1
Conversion is complete
AIR file is bound to version 1.0
app id C6DBEEA1-D1F2-4291-9AC5-CF629633C3FA
application is bound to this version of the runtime
Application is installed? true
Application handles updates; launching it
Failed while converting AIR file: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2004" errorID=2004]
Starting cleanup
Installation exited
quote:
1: create a new user account and move it to the other drive to confirm that you do not see the problem with the new account.
quote:
2: if that is the case, it will appear that there is something in your home that the AIR application installer is incompatible with - we can try to narrow that down further
quote:
3: you said that you repaired your disk for permissions problems -> can you also run Keychain and perform first aid on the Keychain while logged into the account that is giving you problems?
quote:
Originally posted by: Oliver Goldman
@dsa01: We've made progress on some issues and not on others, as this thread makes clear. Note that the "AIR file is damaged" message is somewhat generic, and appears when a number of different individual errors occur.
The error message you encountered and posted above is from an earlier release of AIR. If you could re-try with AIR 1.1, we can take another look at the particular issue on your machine.
quote:
Originally posted by: chrisdat
Link to how to capture install log:
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb403123&sli ceId=1
quote:
Originally posted by: stjohnsj
Oliver: Are you interested in getting the crypto error causing certificate file? If so then contact me directly as I don't want to post someone else's certificate publicly. The problem with the cert is real and 100% reproducible. If the cert is in the keychain, AIR apps won't install. If you delete it, everything works ok.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
