Movement and its effect on file / stream size
Jul 16, 2008 7:12 PM
I am trying to profile the affect of movement on bitrate and therefore the volume of data required to stream flash h.264 video.
The reason why I am doing this is because the studio I am setting up will have a number of LCD video screens behind the presenter on camera. This wall of LCD screens will be displaying different TV feeds. To simulate and analyze the affect of this on stream size - I have setup 6 normal pc lcd screens and pointed a webcam at it. Encoding this video for 1 minute intervals in FME I am comparing the output file sizes after one minute of recording. I started off with no LCD screens displaying anything and worked my way up to having all 6 screens on. I am using the default profile - "Medium Bandwidth H.264 (300kbps)".
My expectation was that with no screens on and therefore no movement other than changes in ambient light - that the file size would be dramatically different than with all the lcd screens showing different tv feeds. This expectation has come out of my research that says when streaming h264 - pframes are sent which include only sections that have changed – as opposed to iframes which have the full frame.
However – when I compare my resulting output files there is no perceived difference in the output file sizes.
Is there some fundamental issue with my testing or my expectation that a stream with a higher bitrates will result in much larger files – given a constant window of time?
Am I missing some settings in FME?
    Jul 17, 2008 3:54 AM   in reply to jimparkins
    On an average the bitrate will remain constant ( 300kbps in your case) for H.264 irrespective of the quality of input video. If the device sends less/more frames than the agreed fps, then the bitrate will decrease/increase accordingly.
    But with vp6, the input video quality may impact the bitrate.
    Jul 30, 2008 8:31 AM   in reply to Moin Ansari
    Hi there,
    intersting point.
    I have another problem: Quality of h.264 video doesn't seem to change, even if we alter the bitrate quite dramastic.
    Eg. 640x480 video looks quite the same, whether encoded with 350kbit or with 1000 kbit.
    That can't be right, especially because the quality is always not great.
    Any thoughts?
    thomas
    Jul 30, 2008 10:54 PM   in reply to jimparkins
    It is very unlikely that the video quality would be same on 350 & 1000kbps.
    1. What is the output bitrate listed in the FME Encoding Log tab?
    2. What is the CPU utilization? If it's greater than 70%, then you may need higher end machines.
