3D Walkthrough : Church
Apr 20, 2008 8:31 AM
This is a real church somewhere in Romania.
http://www.ofmconv.ro/shockwave/bacau.html
I did the AutoCAD -> 3DS Max 2009 -> W3D part (1:1 world scale).
Remus did the rest (a real lesson of lighting and lightmaps).
Less than 1MB to download (including a short sound track).
The CD version takes over 40MB and is much more detailed (more rooms and objects).
This is for testing purposes only, the official launch is on may 12th.
For those interested in Director 11 and DirectX 9:
http://necromanthus.com/Games/ShockWave/bacau_v11.html
    Apr 20, 2008 10:33 AM   in reply to AlinaX
    Hi man,
    Nic job, though for me all the things are too "synthetic". You should
    avoid monnotony of flat, enless surfaces covered with simple repetitive
    texture.
    If you like you may compare your work with this:
    http://www.ziggi.pl/muzeum/scena.html
    Ziggi
    Apr 20, 2008 1:01 PM   in reply to AlinaX
    Nice.
    < 1MB, cool.
    Apr 21, 2008 11:50 PM   in reply to AlinaX
    Hi there,
    Nice 3d church you got there. Try changing the member("3d").camera[1].hither and member("3d").camera[1].yon to get rid of the clipping when standing on the balcony and looking into the church.
    Bey
    Apr 22, 2008 1:55 AM   in reply to Angular Dashpot
    In most of the cases, clipping is related to cheap (ATI Radeon) video cards with 16bit Z-buffer depth.
    As general rule, camera.hither (objects closer to the camera than hither are not drawn) and camera.yon (objects at a distance greater than yon are not drawn) have nothing to do with clipping and is not a good idea to change the default values.
    Cliping is related to world scale and Z-buffer depth.
    In your case, a better video card is needed.
    cheers
    quote:
    Originally posted by: Angular Dashpot
    Hi there,
    Bey
    May 10, 2008 7:04 AM   in reply to AlinaX
    Very impressive!
    May 12, 2008 12:53 AM   in reply to AlinaX
    Hi Alina,
    Real nice! What plug-in have you used for the mousePosition?
    Cheers!
    Arata foarte bine! am facut si eu o prezentare a unei biserici fortificate din zona sibiului, daca vreti s-o vedeti, PM
    si va trimit link-ul . ;)
    May 12, 2008 2:22 AM   in reply to danieloizo
    quote:
    baMoveCursor by Gary Smith (Magic Modules).
    Shockwave Safe and FREE!
    http://www.mods.com.au/xtras/default.htm
    cheers
    Jun 3, 2008 7:31 AM   in reply to Newsgroup_User
    Ziggi
    Love your museum but I seem to have trouble getting right into it, I can only zoom in a little way and can't get right down to floor level. I'd really like to explore it more. Is it because I'm using a Mac??
    EP
    Jun 8, 2008 1:32 PM   in reply to AlinaX
    AlinaX, Ziggi - nice job;
    Ziggi, for your kiosk that has an animated monitor screen, how did you create the animated TV effect?
    my standard method is:
    - stream video ( flv, avi, swf ) into off-stage flash sprite
    - on each frame do a copypixel --> image object
    - update the 'tv screen' with the image object
    is this about the same for you;
    dsdsdsdsd
    Aug 3, 2008 3:31 PM   in reply to dsdsdsdsd
    Very nice work.
    Both, the church and the museum (last ones textures and lightning are very good, but movement is a bit difficult).
    But one question: How did you use the baMoveCursor Xtra?
    I tryed to use it by myself but it won't work online. (It is the same thing like the SetMouseLoc Xtra. The "there was an error cannot proceed" stuff)
    I would like to use baMoveCursor because it is free and supposed to be Shockwave-Safe.
    I followed the instructions but nothing happens.
    Does anyone know how to get it work?
    Aug 3, 2008 11:20 PM   in reply to .ogh_idofi_8tßr_s_gt
    You need to host the packages on your server and you need to include the xtra (Modify/Movie/Xtras/Add).
    Aug 4, 2008 6:07 AM   in reply to Nanomedia
    This is exactly what I already did.
    I created a folder named "xtras", loaded the packeges to the server in that folder and added the line to the xtrainfo.txt: [#namePPC:"baMoveCursor", #nameW32:"baMoveCursor.x32", #package:"myURL/xtras" ].
    Then published it again loaded the dcr-file up to the server but it doesn't work.
    By the way there is no option "download when needed" in Modify/Movie/Xtras when selecting that Xtra.
    And when online it causes the error.
    Aug 4, 2008 6:32 AM   in reply to .ogh_idofi_8tßr_s_gt
    It doesn't work in that way.
    Upload the packages on your server (www.myserver.com/xtras/)
    Quit Director, edit the 'xtrainfo.txt' file and insert this line:
    Open Director, include the Xtra (Modify/Movie/Xtras/Add) and publish the DCR file again.
    Aug 4, 2008 7:56 AM   in reply to Nanomedia
    Thanks.
    Now I can select "download if needed".
    But it still does not work online.
    Guess I have to find another Xtra or another way to create 3d mouse navigation.
    Aug 4, 2008 2:27 PM   in reply to AlinaX
    there both good but I saw an earlier version of that room ziggy did this one looks better the animation on the wall and the sliding animation makes a lot of difference. the dark feel with the highlighted pictures works well. I didnt realize it at first but its interactive, well done. but I dont like the way it turns you around. during some collisions. the church could stand next to other web 3d programs that are stronger than director, good job
    Aug 5, 2008 1:40 AM   in reply to tyree_2
    Thanks.
    Can you give more details?
    Did you try to contact the author (Gary Smith)?
    quote:
    Awesome image quality in Shockwave 3D.
    Aug 5, 2008 11:26 AM   in reply to Nanomedia
    a couple of 3d apps to look at:
    toddanddotty - gallery
    toddanddotty - 9-story condo
    a couple from our competitor ( but they're good ):
    habitect - apartment
    habitect - gallery .... then click "Vista Virtual" tab
    dsdsdsdsd
    Aug 6, 2008 1:41 AM   in reply to dsdsdsdsd
    Very nice.
    Aug 6, 2008 7:39 AM   in reply to Nanomedia
    Director Shockwave is not dead?
    Of course it's not! It's just awfull!
    This has just been released using director -> http://www.battlemailkungfu.com
    It's not bad at all, but you can see that the 3D is still dated by shockwave 3D.
    Aug 23, 2008 5:04 AM   in reply to AlinaX
    how do you make the mouse to rotate camera in 360 degrees?
    Sep 12, 2008 3:07 PM   in reply to AlinaX
    dsdsdsdsd, thanks
    Jan 19, 2009 3:07 AM   in reply to AlinaX
    hey Alinax
    it's gr8....
    i loved the smoothness when moving the mouse and when moving the camera forward..
    it's really gr8!!!!!
    i'm developing my own first person shooter scene. so i'll be glad if u can help me out...
    please if u can reply on my email !
    regards,
    Genius
    Jun 22, 2010 2:34 AM   in reply to AlinaX
    here is a virtual museum for a woman named Alma Karlin ... she is a historical figure from Celje, Slovenia, known for her early 20th century world travels, a Slovenian Darwin/Lindberg if you will:
    http://www.pokmuz-ce.si/alma3d/
    we developed this site for Pokrajinski Muzej in Celje, Slovenia.
    dsdsdsdsd
    Nov 8, 2010 6:04 AM   in reply to AlinaX
    These are all amazing pieces of work.
    How did you start off these projects? I am new to director and am making something just like this for my Final Year Project. Though at the moment, I am just really struggling with importing a w3d file and being able to see it.
    Nov 8, 2010 2:38 PM   in reply to ptemedia1
    that's the right way to start ...
