CFQUERYPARAM and text datatype
Sep 02, 2008 Sep 02, 2008
What is the proper cfsqltype for a text/ntext datatype?? I've used char, varchar and longvarchar and all of them give me invalid parameter bindings.
The query code:
<cfquery name="querynam" datasource="#DSN#">
SELECT v_id FROM tblV
WHERE v_keywords LIKE '%<cfqueryparam cfsqltype="cf_sql_longvarchar" value="#form.search#">%'
</cfquery>
Paul Ferree
3.6K
LEGEND , Sep 02, 2008 Sep 02, 2008
paulferree wrote:
> Query Parameter Value(s) -
> Parameter #1(cf_sql_char) = '%hotel%'
> Thanks
I just did a test, I think you have two many quotes in your query.
SELECT * FROM art WHERE ARTNAME LIKE ?
Parameter #1(cf_sql_varchar) = %Do%
Notice that the Parameter does not have quotes around it. I think you
had this.
LIKE <cfqueryparam cfsqltype="{your choice here}"
value="'%#form.search#%'">
Which would search for the string '%hotel%' not the desired %ho...
> The query code:
> </cfquery>
> Thanks!
> Paul Ferree
I don't think your problem is a inproper datatype, but just plain bad
sysntax. You can not bind part of a value like you are. The entire
value, quotes and percents must be part of the bound value.
I.E.
LIKE <cfqueryparam cfsqltype="{your choice here}" value="%#form.search#%">
Well...I tried that, but when I put the entire value in there the returned rows are 0.
If I do the exact same query removing the cfqueryparam, it pulls up 45.
Here is the cf debugging info:
SELECT vendor_id FROM tblVendors
WHERE vendor_keywords LIKE ?
ORDER BY vendor_package_id DESC, vendor_company ASC
> are 0.
What is the EXACT syntax you used for the <cfqueryparam>, using Ian's
suggestion (which is correct)?
Adam
> Thanks
Just to be clear here, you are saying that the following query returns
45 records, but the above one does not?
WHERE vendor_keywords LIKE '%hotel%'
This is the exact query:
<cfquery name="getvendors" datasource="#DSN#">
WHERE vendor_keywords LIKE <cfqueryparam cfsqltype="cf_sql_char" value="'%#form.search#%'">
</cfquery>
Paul
> Thanks
had this.
Which would search for the string '%hotel%' not the desired %hotel%.
Get rid if the extra quotes if you have them.
You have an extra set of single quotes in your value there. When one is
using <cfqueryparam> one does not need the quotes around string values.
It's probably good to familiarise yourself with the documentation for any
tag / function you use, before using it:
http://livedocs.adobe.com/coldfusion/8/Tags_p-q_18.html
Adam
As I just said too many quotes in there. You just need one set. Either
will do: value="%#form.search#%" OR value='%#form.search#%' otherwise
the inner quotation marks become part of the string the database is
trying to match.
Bingo! That was the problem...thank you very much.
Inching ever so slightly towards never making stupid mistakes...haha...right.
Thanks again guys,
Paul
Documentation
