Report Builder and RDS
Sep 9, 2008 8:22 AM
I just installed CF 8.1 Report Builder and attempted to use it for the first time.
Is it required to have RDS activated on the server in order to use report Builder?
    Sep 9, 2008 8:31 AM   in reply to Russ
    I do not think it is *required* but I believe report builder will
    definitely be limited by not having access to RDS to provide graphical
    integration with database objects.
    Sep 9, 2008 9:23 AM   in reply to Russ
    http/1.1 404 not found
    Is that an exact copy from the error message?
    If so, then something is wrong somewhere in your configuration, since
    http:/1.1 is never going to resolve to a http connection. It is not a
    complete IP address.
    I would expect to see something like:
    http://127.0.0.1
    OR
    http://localhost
    OR
    Whatever is required to connect to the ColdFusion server to which you
    are trying to connect.
    Sep 9, 2008 9:27 AM   in reply to Russ
    Russ wrote:
    > OK, that makes sense except that I know that using RDS in prior releases of CF
    > gave programmers full access to server drives and folders, a risky situation.
    P.S.
    Yes RDS does give programmers a great deal of access to a server and it
    is a risky situation. That is why all the documentation says to *NOT*
    allow RDS on production servers, only development servers. And to take
    whatever other precautions you deem necessary to restrict the access to
    even the development server to only those who should have access.
    Sep 24, 2008 8:10 PM   in reply to Russ
    i got the same situation.
    i installed CF 8 and report builder on an intranet-connected machine and the RDS service worked just fine with the host name set to "localhost", then i installed another report builder on my own machine tried to connect to the previous machine ,after i typed in all the information required by the configuration and clicked test connection ,i got the message "A connection to the RDS server could not established because the web server was unreachable." the host name is set to the ip address of that server and it just could not work.
    Oct 9, 2008 4:33 AM   in reply to Russ
    swangstw, interesting writeup thank you.
    Oct 9, 2008 8:20 AM   in reply to Russ
    Another thought: this can also happen if RDS is disabled. Check that *both* RDS sections of the web.xml are uncommented.
    see
    http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_17276
    Oct 18, 2008 6:35 AM   in reply to Russ
    Thanks a lot
    Oct 27, 2008 1:03 PM   in reply to Russ
    I have a local install of CF 8 developer edition and have the same problem with report builder and RDS. I've checked the web.xml file and its correct. Any other ideas?
    Nov 10, 2009 12:06 AM   in reply to Russ
    i have the same problem...how connect the rds directly to my datasource..same error also...anyone who can help?
    Nov 10, 2009 12:48 AM   in reply to jepoy1
    It can be solved either through,
    Installing ColdFusion using the integrated web server (port 8500).
    By turning off IIS Integrated Authentication on the CFIDE directory (use the admin password to secure it instead).
    HTH
    Nov 10, 2009 12:57 AM   in reply to Daverms
    I have tried it and it doesn't work for me..I also restart the services of IIS and Coldfusion.
    Anyway..thanks for the help. Hope that anyone can help me.
    thanks
    Mar 15, 2010 2:06 PM   in reply to Russ
    Exactly the same problem here
    Windows 7 IIS7  Local installation
    None of the obvious steps works.
