Is there a way to avoid the error and avoiding the need to write seperate queries
Enthusiast ,
Nov 03, 2008 Nov 03, 2008
Say I have a query that uses a param in the sql :
<cfqueryparam value="#arguments.forwardValue#" cfsqltype="cf_sql_integer">
However sometimes the value forwardValue will contain nothing ie nothing entered in the text input.
This will generate an error from the CF side. Is there a way to avoid the error and avoiding the need to write seperate queries?
Database access
854
Do some if/else logic to create a variable that will be either true or false, depending on whether or not arguments.forwardvalue is an integer. Then use that variable in the null attribute of cfqueryparam.
Valorous Hero ,
I think CF always validates the value, even when you are using the null attribute. So you may have to resort to using val(arguments.forwardValue) in combination with the if/else logic for the null attribute
<cfqueryparam value="#val(arguments.forwardValue)#"
null="#not IsNumeric(arguments.forwardValue)#">
Mentor ,
Try this.....
<cfqueryparam value="#arguments.forwardValue#" cfsqltype="cf_sql_integer" null=#not isNumeric(arguments.forwardValue)#>
Phil
Valorous Hero ,
Hmm.. I guess I was wrong about that. I just tried it with MS SQL and it works just fine ... _without_ the val(..)
Enthusiast ,
I just changed they type in CF to string and it wasn't fussy anymore
quote:
If the db field is integer, send your function a non-numeric string and see how fussy your db gets.
Valorous Hero ,
That will also allow invalid values like "abc this is not an integer" to pass through to the database, resulting in an ugly conversion error. Using the "null" attribute, as suggested, will validate the values _before_ the query executes. There is little point in hitting the database if the statement will fail anyway.
Documentation
