I think I just found something that may help you. I'm
actually looking to do nearly the same thing. I have a externally
loaded FLV in a scene. When that FLV ends, I'd like to to load
another scene -- Can this code I'm giving you be changed to do
that?
Here's teh description, then the code from Adobe:
Playing multiple FLV files
You can play FLV files sequentially in an FLVPlayback
instance simply by loading a new URL in the contentPath property
when the previous FLV file finishes playing. For example, the
following ActionScript code listens for the complete event, which
occurs when an FLV file finishes playing. When this event occurs,
the code sets the name and location of a new FLV file in the
contentPath property and calls the play() method to play the new
video.
import mx.video.*;
my_FLVPlybk.contentPath = "
http://www.helpexamples.com/flash/video/clouds.flv";
var listenerObject:Object = new Object();
// listen for complete event; play new FLV
listenerObject.complete = function(eventObject:Object):Void {
if (my_FLVPlybk.contentPath == "
http://www.helpexamples.com/flash/video/clouds.flv")
my_FLVPlybk.play("
http://www.helpexamples.com/flash/video/water.flv");
my_FLVPlybk.addEventListener("complete",
listenerObject);
