Flash.ocx cannot be found: The reason this could be giving you this error is because if you've recently updated Flash Player from a very old version to a new version. They changed the name of the .OCX file in that program to flash###.ocx (the # being the version of the player). You may have an old screen saver that uses flash.ocx. To fix you can go to your Macromed folder (usually in your Windows\System32 folder. Copy the current flash###.ocx file then save in the same folder here as flash.ocx. You will now have two .OCX files with different names. You shouldn't get the error message anymore
This has been a problem for quite a while in our company and it's pretty much an everyday occurrence.
We have around 500+ that get the exact same error: cannot find flash.ocx
The work around we use is to copy the Flash.ocx file from one PC that still has it and paste it into the C:\WINDOWS\system32\Macromed\Flash directory of the PC that has the problem.
In our case renaming the current updated file Flash10d.ocx to Flash.ocx also works but this may not work for you.
Now the two work arounds above are fine but as soon as adobe has an update the file is once again replaced with the latest updated file! And you have to perform the work around again.
You can see what the update does by looking at the install.log file located in the same directory. It’s just a text file so you can view it in Notepad C:\WINDOWS\system32\Macromed\Flash
Bellow is a snipet of log file:
IfFileExists: file "C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe" does not exist, jumping 948
IfFileExists: file "" does not exist, jumping 952
Delete: "C:\WINDOWS\system32\Macromed\Flash\Flash.ocx"
Delete: "C:\WINDOWS\system32\Macromed\Flash\Flash6.ocx"
Delete: "C:\WINDOWS\system32\Macromed\Flash\Flash6a.ocx"
The bellow does not work but interesting at that:
I did try editing the screen saver file directly to point it to a different directory, in which I would then place the Flash.ocx file but unfortunately although the .scr file can be viewed in Notepad, making a change to the file will destroy it. Please make a backup of the file first if you want to see whats inside. You can use Ctl + F to search for Flash.ocx etc..
Although not really a hindrance in day to day work screen burning could potentially be an issue!
Hope this helps someone.
Simon
