Flash Player Doesn't Work on Some Websites
May 7, 2012 9:49 PM
Tags: #box #not_working #player #black_square #black_window
On some websites Flash content loads normally (for example it works great on youtube, hulu, and dailymotion), but on other websites it does not work at all.
On many websites (for example, on the MTV or Comedy Central websites), I get a black box where the video should be, but no ad or video ever shows up. If I right click in the black box, I get the following options:
- Settings...
- Global Settings...
- About Adobe Flash Player 11.2.202.235...
I have tried IE and Chrome.
I've tried uninstalling/reinstalling flash.
I've tried deleting all site Data and Settings.
I've set it to allow sites to save information to my computer.
I'm running the latest version.
My system is an AMD A6-3400M, 6GB Ram, Windows 7 Home Premium 64bit. I've tried IE9 and Chrome - same issue with both browsers.
Any help would be greatly appreciated!!
    May 7, 2012 8:38 PM   in reply to jbj7077
    Does it get better if you disable Hardware Acceleration?  (See How do I disable or enable hardware acceleration? )
    What is your display adapter, driver version and date?
    May 8, 2012 1:04 AM   in reply to jbj7077
    Can you go and check if there is a newer driver available for your graphics card: http://support.amd.com/us/gpudownload/windows/Pages/auto_detect.aspx
  • Chris Campbell
    May 4, 2010
    May 11, 2012 4:36 PM   in reply to jbj7077
    Does it matter if you clear out your flash player cache?
    How do I clear my Flash Player cache and settings?
    Jun 3, 2012 3:08 PM   in reply to jbj7077
    I've been having this exact same problem for a couple weeks now.  Comedy Central videos won't play, neither will some (not all) at MLB.com.  I've tried all the tips here and none seem to work.  What's odd is that my Guest Account will play these without any problem, so it must be something to do with my overall Flash preferences (IE, Safari, and Chrome all fail to play at these websites), but I can't figure out what's changed to make this a problem.  Any ideas?
  • Chris Campbell
    May 4, 2010
    Jun 6, 2012 3:46 PM   in reply to mystdni
    That's odd that a different account on the same machine is able to play them back.  Could you be using any other software on your normal account that could be conflicting?  Sometimes ad blockers or virus/security software can interfere here.  If all the software is equal, I'd recommend trying to fix permissions to see if that's an issue.
    How do I fix Windows permission problems with Flash Player?
    Jun 16, 2012 12:12 AM   in reply to jbj7077
    Well for me, I got the same problem.One some pages like Facebook it's no problem to play the online games. But when I try on Newgrounds there stays just an empty space.
    I am using Win7 64bit
    Google Chrome
    ATI Radeon HD 5750
    Intel Core2Duo CPU E6750
    Until now I reinstalled Chrome and Flash Player several times. I cleared the Flash Player cache. I installed updates for Java and my graphic directX
    Could it be a problem if Chrome has 2 versions of Flash avialble?
    copied from Chrome://plugins
    Flash (2 files) - Version: 11,3,300,257
    Shockwave Flash 11.3 r300
    Beschreibung:     Shockwave Flash 11.3 r300
    Speicherort:     C:\Users\XXX\AppData\Local\Google\Chrome\Application\ 19.0.1084.56\gcswf32.dll
    Typ:     NPAPI        Deaktivieren
    MIME-Typen:      MIME-Typ     Beschreibung     Dateiendungen
    application/x-shockwave-flash     Adobe Flash movie      .swf application/futuresplash     FutureSplash movie      .spl
    Version:     11,3,300,257 Speicherort:
    C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_257.dll
    A quick answer would be great.
    Jul 7, 2012 4:04 PM   in reply to jbj7077
    I've had the same problem for quite some time ... very frustrating!  On my desktop computer, I am unable to see an embedded flash object type application/x-shockwave-flash.  This is in all browsers ... IE8, IE9, Firefox 11, Firefox 13, Opera, Safari.  At one point I uninstalled flash and shockwave, uninstalled all browsers, cleaned up leftover files and registry entries, and then reinstalled the browsers and flash after disabling my firewall and my antivirus ... and it didn't make any difference.  My sister and a friend have the same problem, with different version of windows and different firewall/antivirus.
    My laptop shows the flash objects just fine!
    Based on another post by a user named Treuben, I enabled my Guest account in Windows 7, and logged in to it ... and the flash plays just fine in Firefox 13 (my default browser).  I did not reinstall or change anything about the browser installation or the flash installation.
    I have no idea what the story is.  If I get enough time, perhaps I'll try and isolate the issue ... I'm an equipment tech, so I'm always curious about why something acts up.
    But I'm building a new desktop computer from scratch, so I may just see if it works okay on the new installation.
    The only common thread I've seen so far is that Treuben and I both have Wacom tablets.
    Good luck to all.
    Tim
    Jul 11, 2012 2:09 PM   in reply to jbj7077
    Walrus50
    You are correct  by logging on as a Guest account account I am able to overcome the problem of not being able to access some web sites.   Had been trying for months and this works thanks...
    If you can isolate the core broblem please post I am very interested.
  • Chris Campbell
    May 4, 2010
    Jul 11, 2012 5:56 PM   in reply to Den321
    If the guest account works, then I suspect you might be running into file/folder/registry permission issues.  Please try the steps outlined in this FAQ:
    Jul 12, 2012 3:26 AM   in reply to Chris Campbell
    Chris Cambell outlined a format which I tried without success...
    Please post any new solution.   Am very interested to solve..
    Jul 13, 2012 12:29 AM   in reply to Chris Campbell
    Thanks for the info, Chris ... but I don't have a problem with flash player.  As I said, I can see pretty much all flash displays on all websites using all browsers ... except of the type EMBEDDED.
    Flash installs fine, and I see the animation after the installation.  Shockwave installs fine, and I see the animation after the installation.  I've done this many times.
    But on some sites, such as this one ( http://www.vermontcountrystore.com/store/jump/productDetail/Clothing/M en&aposs/Shirts_&_Pants/Men&aposs_Denim_Shirt/60202 ), I do NOT see their display.  I get a message saying "one moment please", and then a message saying "please try again later.  our apologies".  When I right-click on the image space, I get the Flash Player menu, the bottom item of which says "About Adobe Flash Player 11.3.300.262".
    I get the same issue when trying to view available tickets for SOME venues on Stubhub.com.
    This issue is, as I stated, the same in ALL of the browsers I've tried.
    My HTML and Javascript skills are weak, so I'm not certain ... but when I've viewed the page source, it always appears that I find an "embed" tag for the images that I fail to see.  I believe this code snippet ( swfobject.embedSWF("http://s7d5.scene7.com/is-viewers-3.8/flash/genericzoom.swf?serverUrl= http://vermontcountrystore.scene7.com/is/image/&contentRoot=http://s7d 5.scene7.com/skins&config=vermontcountrystore/vcsconfig&image=vermontc ountrystore/60202", "myContent", "265", "550", "7.0.0", "expressInstall.swf", flashvars, params, attributes); ) is the line for the image (with zoom) that I can't see on that particular site.
    I considred a problem with RealPlayer, so tonight I uninstalled RealPlayer, cleaned up leftover files, and then spent about an hour going through the registry to clean up any leftover references to RealPlayer ... but it made no difference.
    Sorry to be so wordy, but I've been a troubleshooter for over 30 years, and I know a small detail can suddenly make something clear.
    Jul 28, 2012 3:16 PM   in reply to jbj7077
    I found da solution 4 da problem. Its bcoz some of dem sitez n33d ² save permanent data on your PC, but fail ² do so becoarse of sum fcked up write permissions. Go ² da Application Data folder ( %AppData% ) and look for da folder called "Macromedia". Right-click da folder and click dem properties ² bring up da properties window. Switch ² da Security tab and check if dem write permissions R correct. If in doubt, create a new entry "Everyone" with all dem permissions given and let all dem underlying files and folders inherit dem permissions. Click OK.
    Then surf ² http://www.macromedia.com/support/documentation/de/flashplayer/help/se ttings_manager03.html
    And tik all dem chekboxes and allocate 100kb of space.
    Sh*t be working again now. Have fun.
    Dec 4, 2012 4:13 PM   in reply to Walrus50
    Dec 4, 2012 11:05 PM   in reply to gabrio-81
    I played with the Adobe Flash Settings Manager, as the previous poster suggested.  Of all the settings, I found that checking the box labeled "Allow third-party Flash content to store data on your computer" in the Global Storage Settings tab made the difference ... even with the amount of storage allowed set to zero!
    http://www.macromedia.com/support/documentation/en/flashplayer/help/se ttings_manager03.html
    I tried the link I posted earlier for the denim shirt at the Vermont Country Store, and with that box checked the imaged displayed and zoomed as it should.  If I uncheck that box, I get the same failure as before.
    I also just tried it with IE8 and Opera 12 ... they both worked fine, after bringing up a box asking me to allow 10kb of local storage.
  • Chris Campbell
    May 4, 2010
    Dec 10, 2012 3:25 PM   in reply to Walrus50
    If anyone in the thread is having problems with embedded content and would be willing to do a desktop sharing session with me so I can take a look at your system, please shoot an email to ccampbel@adobe.com and I'll try and schedule a time with you.
    Dec 30, 2012 8:38 PM   in reply to jbj7077
    i had the same problem and i fixed it by resetting my host file to default:
    http://support.microsoft.com/kb/972034
Bookmarked By (2)
