What causes this...?
May 8, 2012 9:43 AM
  Latest reply: Jay Gladwell, May 8, 2012 6:29 PM
    May 8, 2012 12:29 PM   in reply to Jay Gladwell
    Hi jay
    What's the graphic card model? please tell us the driver version number. you can check it on dxdiag dialogue box.
    for re-creating preferences:
    Go to C:/Users/username/appdata/roaming/adobe/premierepro/6.0
    Rename 6.0 to 6.0.old
    This will trash the preferences.
    May 8, 2012 12:31 PM   in reply to Jay Gladwell
    Create a synthetic clip eg Color Bars ....and try that in the source or Program Monitors.
    Check the display settings-  Preferences.  ( Yesterday at first trial...I spotted a 3d check box somewhere and cant remember if it was in PPRO CS6 or SpeedGrade)
    May 8, 2012 12:42 PM   in reply to Jay Gladwell
    (Freakin' eh, I HATEHATEHATE this stupid forum layout! GRRRRRRR...)
    OK, do you have MPEG StreamClip? If not, Google it up and download it; it's free. Open one of the clips showing the problem in MPEG StreamClip, and then go to File > Save As, and then pick a new name for the file and save it. Try importing this clip into CS6 and see what happens...
    (You can also do this with QT Pro, if you already have that installed. QT Player won't do it, which is why I suggested MPEG Stream Clip.)
    May 8, 2012 1:15 PM   in reply to Jay Gladwell
    Very weird. That makes me think maybe it's Pr itself. Do you have a shorter clip you can upload that is showing the problem? You know how to get a hold of me...
    I don't believe this is a GPU driver issue; if that were the case, all your clips would show this in the PM, and not just some of them.
    May 8, 2012 1:20 PM   in reply to Jay Gladwell
    The drivers are latest.
    Did you try re-creating preferences?
    Jay, can you check the quicktime version ? windows or mac?
    May 8, 2012 2:20 PM   in reply to Jay Gladwell
    Reset Corrupted Preferences = Press/HOLD Ctrl+Alt+Shift while starting program
    May 8, 2012 4:57 PM   in reply to Jay Gladwell
    Maybe you need a later driver
    http://www.geforce.com/drivers/results/43997
    May 8, 2012 5:21 PM   in reply to Jay Gladwell
    .mov file shot with a Canon 5D MkII.
    Try simply renaming the extension from .mov to .mpg, and then import the clip  See if that helps.
    May 8, 2012 5:44 PM   in reply to Jay Gladwell
    Are you in software mode or gpu mode?  Try switching and see if you have different results. Project > Project Settings > General > Mercury Playback engine...
    May 8, 2012 6:07 PM   in reply to Jay Gladwell
    Try uploading a clip to a file sharing site.  (I like the below, myself.)  Let others test in their version of CS6.
    http://www.depositfiles.com/en/
    May 8, 2012 6:10 PM   in reply to Jim Simon
    @ Jim Simon
    Just renaming the file does not fix it.
    I downloaded a short sample awhile back of this video.
    Last time I used VLC to convert it to mpeg and it worked but with the new version of VLC it wont convert to anything playable.
    @ Colin
    I was able to convert with MPEG Streamclip and it plays fine in CS5.5
    @ Jay
    Here is a screen cap with it working.
    Like everyone else the new forum does suck for now.  At least I think they are working on it from what I have read.
    Not knowing who is replying to who sucks.
    GLenn
    May 8, 2012 6:12 PM   in reply to Jay Gladwell
    Hi Jay,
    What you're seeing looks like what happens when there is a mis-translation between YUV and RGB (green and pink from black and rowbytes errors). Something rather odd is happening. I can't see this having anything  to do with your graphics hardware, but I can totally see it being caused by a damaged or otherwise 'unexpected' form of file. Since PPro can handle H.264 files (they are .mov internally regardless of their extension) 'natively' (meaning that it doesn't have to use Quicktime to read them), it makes me wonder - is the same rendering you're seeing the same on all of the files from your 5dMarkII, or just this one?
    -EricS
    (adobe engineering)
    May 8, 2012 6:26 PM   in reply to EricSanders_
    @ Jay
    Just for fun I loaded it into CS4 and it works just fine in the .mov format.
    Who knows.
    There does seem to be some bad frames in the beginning.  The first 6 frames are bad.  Maybe that is doing it.
    I dont have CS6 so cant test there.
    GLenn
