JDeLuca9198
How do I abbreviate FlexGlobals.topLevelApplication.componentInstance.componentInstance?
May 8, 2012 9:26 AM
I've created a Flex 4.6 web application that has many instances that need information from each other. Originally, I used a singleton to store the reference to the instance which was real convienent and works fine.
I am refactoring it to use FlexGlobals.topLevelApplication to access the instance instead of an extra singleton class.
Example 1:Singleton code that i am refactoring looks something like this and does work:(this works just fine but uses an extra class for storing the reference)
//ViewHDDComp.mxml
import HDD.Classes.HDDGlobals;
private var hdd:HDDGlobals= HDDGlobals.getInstance();
hdd.ViewHDD.menuButtons.visible=false; //the reference to the menuButtons component is stored in the HDD Globals
hdd.ViewHDD.menuInput.visible=false; //the reference to the menuInput component is stored in the HDD Globals
//HDDGlobals.as
private var _viewHDD:ViewHDDComp;
public function get ViewHDD():ViewHDDComp { return _viewHDD; }
public function set ViewHDD(viewHDD:ViewHDDComp):void{_viewHDD=viewHDD;}
Example 2: This is what I am trying to do which does not work:(don't understand why it doesn't)
//ViewHDDComp.mxml
import HDD.Components.ViewHDDComp;
private var h:ViewHDDComp=FlexGlobals.topLevelApplication.viewHDD;
h.menuButtons.visible=false; //menuButtons is a component in the instance viewHDD component
h.menuInput.visible=false; //menuInput is a component in the instance viewHDD component
This is what does work:(but is too verbose)
//ViewHDDComp.mxml
FlexGlobals.topLevelApplication.viewHDD.menuButtons.visible=false; //menuButtons is a component in the instance viewHDD component
FlexGlobals.topLevelApplication.viewHDD.menuInput.visible=false; //menuInput is a component in the instance viewHDD component
How do I abbreviate or type cast FlexGlobals.topLevelApplication.componentInstance.componentInstance.c omponentInstance?
Thanks in advance,
Joe
    May 8, 2012 1:40 PM   in reply to JDeLuca9198
    My first question would be why do you want to remove the singleton and its references?
    I think your original method is much better than the new one you are trying to do
    May 8, 2012 2:29 PM   in reply to JDeLuca9198
    I have to say im not exactly sure
    It’s interesting actually, Ive never really thought of doing it your way.
    As it happens Im just about to go to bed, the perfect place to ponder on the question. J
    I’ll have a look in the morning and try accessing some stuff the FlexGlobals way, and see how it works out.
    I think Ive only ever referenced FlexGlobals.tLA when using it to position a pop up window.
    Off the top of my head im not sure why your code isn’t working. It looks like it should
    Anyway, I’ll have a look in the morning
    Good luck and nice to speak to you
