What happens to archieved folios?
May 8, 2012 12:36 PM
Tags: #content_viewer
I clicked "archieve" and now i cant get my foloio back to my ipad.
Any help is appreciated!
  • Bob Bringhurst
    May 29, 2007
    May 8, 2012 12:52 PM   in reply to al_me
    Tapping the Archive button removes the folio from your device. However, if your folio has been removed from the server, it disappears from your device. Did you create the folio, or did someone share it with you?
  • Bob Bringhurst
    May 29, 2007
    May 8, 2012 1:32 PM   in reply to al_me
    If you log in using the same Adobe ID you use to create the folio, it should appear. Try signing in to both the Adobe Content Viewer and the Folio Builder panel using the same Adobe ID. If the folio appears in the Folio Builder panel but not the Adobe ID, there might be something wrong with the folio, such as articles with different orientations.
  • Casey Jensen
    May 4, 2011
    May 8, 2012 2:24 PM   in reply to al_me
    I'm going to guess everything works fine on your other two ipads because you simply haven't archived the folio on them.
    If you archive the folio on them, is it once again available for download on those devices?
    If not this means that either:
    • The folio has been removed from the server/the Folio Producer Service
    • There is an article with an invalid orientation that has been imported into the folio.
    • The folio has some sort of corruption at an article level.
    The best scenario to do here is backtrack on any articles you've added or recently changed/re-imported.
    Unfortunately, this is a problem Adobe does not make very easy to troubleshoot.
