trouble debugging with Flash Pro CS6
May 8, 2012 12:21 PM
I have a project I am working on that was created in CS5.5 targeting iOS. The SWF has a lot of content, but no code and the .AS file has all the code except for a few utility functions. I just updated to CS6 and now debugging no longer works as expected. When I run the app in Debug - whether using the mobile or desktop Air debugger environments, it fails to recognize the .AS file as having executable code in it. In CS5.5, when I did this, the AS file would open and I could set and clear breakpoints. Now, if I go to the file and try to toggle a breakpoint, it shows "No exectuable code..." no matter where I set the breakpoint. The app is running fine, but it acts like there is no link between the source file and the app.
The app builds and runs fine - I just can't debug it. Help!
I am sure this is some stupid little thing I haven't done, but since I changed nothing between CS5.5 and CS6, I have no idea where to look.
Scott
    May 9, 2012 11:52 PM   in reply to scober99
    Hi Scott,
    I would like to have a look at your project file for getting more information about the problem. Is it possible for you to share the .fla and .as files?
    Thanks!
    Mohan
    May 11, 2012 7:46 AM   in reply to scober99
    Are you putting a breakpoint on something that isn't code, like a empty line, a brace, etc? Try altering that to be on a line that has code on it. (I know we should be able to set breakpoints anywhere, but I'm curious).
    e.g.
    for (var i:int = 0; i < 100; i++)  // set a breakpoint here
    { // do not set a breakpoint here
         trace(i); // set a breakpoint here
    } // do not set a breakpoint here
    I'm wondering if it considers empty lines, braces and other things to be invalid for a breakpoint location.
    Jun 15, 2012 1:51 AM   in reply to scober99
    You could share the files using dropbox public link ?
    May 6, 2013 3:05 AM   in reply to aviPro
    same bug here
    any news on this?
