After Effects error: Ray-trace 3D ( 5070 :: 0 )
May 8, 2012 3:21 PM
I am trying to create extruded vector shapes in AE CS6 and get the below error after clicking on the enable 3D toggle for the layer.
After Effects error: Ray-trace 3D: Out of paged mapped memory for ray tracer.
( 5070 :: 0 )
Any thoughts on how to solve this?
Branched to a new discussion.
Replies 1 2 3 ... 8 Previous Next
    May 8, 2012 3:59 PM   in reply to adam@blueapplestudio
    Tell us about you computer system, including GPU and OS.
    May 8, 2012 4:30 PM   in reply to Todd_Kopriva
    I am having the same error message when I click on ray-trace 3d option. I am running OSX 10.7.3, 2.4 ghz I7 with a AMD Radeon HD 6770M graphics card.
    May 8, 2012 8:05 PM   in reply to adam@blueapplestudio
    Hi Adam,
    Did you have the latest drivers installed from NVidia?
    --chris
    May 8, 2012 9:37 PM   in reply to ChrisProsser
    Also, if you open Previews preferences (Preferences > Previews) and click the GPU Information button, what appears in the dialog box? You can click the Copy button at the bottom of the dialog box, then paste that here.
    May 9, 2012 3:06 AM   in reply to Jeff Almasol
    have the same problem... here my informations
    Schneller Entwurf:Verfügbar
    Strukturspeicher:400.00 MB
    Ray-tracing:CPU
    (GPU nicht verfügbar - inkompatibler Geräte- oder CUDA-Treiber)
    OpenGL
    Hersteller:ATI Technologies Inc.
    Gerät:ATI Radeon HD 6750M OpenGL Engine
    Version:2.1 ATI-7.18.11
    Gesamtspeicher:1.00 GB
    Schattierungsmodell:-
    CUDA
    Treiberversion:-
    Geräte:-
    Aktuell nutzbarer Speicher:-
    Maximal nutzbarer Speicher:-
    May 9, 2012 6:56 AM   in reply to adam@blueapplestudio
    I am also experiencing the same error. As a quick work around while creating your masterpiece, I changed by view to Fast Draft (the box with the lightning inside). However, when trying to render whether in foreground or background ends up in the same 5070 :: 0 Failure
    Here are my card specs as well for the devs:
    Fast Draft:Available
    Texture Memory:512.00 MB
    Ray-tracing:CPU
    (GPU not available - incompatible device or CUDA driver)
    OpenGL
    Vendor:ATI Technologies Inc.
    Device:ATI Radeon HD 5870 OpenGL Engine
    Total Memory:1.00 GB
    Shader Model:-
    CUDA
    Driver Version:-
    Devices:-
    Current Usable Memory:-
    Maximum Usable Memory:-
    May 9, 2012 8:35 AM   in reply to Jeff Almasol
    Hi
    Same trouble...here are my specs
    I m in Imac 27inches
    3,4 GHz Intel core I7
    16 Go 1333 MHz DDR3
    AMD Radeon HD 6970M 2048 MB
    Mac OS X Lion 10.7.3 (11D50)
    Texture Memory:818,00 MB
    Ray-tracing:CPU
    OpenGL
    Device:ATI Radeon HD 6970M OpenGL Engine
    Total Memory:2,00 GB
    Shader Model:-
    CUDA
    Driver Version:-
    Devices:-
    I really hope you can help...If that feature doesn t work...I won't buy the product...and I badly need it !
    Thanx so much !!!
    May 9, 2012 8:46 AM   in reply to adam@blueapplestudio
    Same Error: using Mac OS Lion 10.7.3 and ATI Radeon HD 5510 1024 Mb, 24 GB ram with 17 GB available for after effects.
    Cannot use Raytraced 3D renderer at all, very dissapointing.  Adobe, any plans to fix so AE CS6 has 3D raytracer support for Mac and ATI?
    May 9, 2012 8:47 AM   in reply to Adamdanielpalmer
    Texture Memory:768.00 MB
    Ray-tracing:CPU
    OpenGL
    Device:ATI Radeon HD 5770 OpenGL Engine
    Shader Model:-
    CUDA
    Driver Version:-
    Devices:-
    May 9, 2012 8:57 AM   in reply to adam@blueapplestudio
    Hey Adam,
    You seem to the odd man out in this thread as you are running windows. Can you try installing a new driver (or re-installing your current one)?
    http://www.nvidia.com/Download/index.aspx?lang=en-us
    We've seen problems like this when there is an odd CUDA version mismatch.
    Those of you on the mac, standby, we're getting Nvidia on the horn to help out.
    --chris
    May 9, 2012 9:01 AM   in reply to ChrisProsser
    Incorrect. I am using Mac OS 10.7.3 Lion.
    Adam
    May 9, 2012 9:02 AM   in reply to Adamdanielpalmer
    Any other information I can provide?
    For the record, my copy of CS6 trial at home on windows 7 works beautifully.  However, I am at work at Sinclair Broadcast Group and there is currently no functioning raytrace 3D Mac OS Lion.
    May 9, 2012 9:06 AM   in reply to Adamdanielpalmer
    May 9, 2012 9:09 AM   in reply to Adamdanielpalmer
    Think I got the wrong adam, sorry!  Thanks for the help.
    May 9, 2012 9:14 AM   in reply to Adamdanielpalmer
    Thanks for the update Chris. I would not be surprised if this is an OS / other application problem. This fails on my Mac Pro, but my Mac Book Pro works fine, both without CUDA cards. I have seen issues in the past that other software has installed kernel extensions or other drivers that create conflict.
    May 9, 2012 10:52 AM   in reply to Adamdanielpalmer
    same error here. Running on 10.7.3 Lion.
    GPU info:
    Texture Memory:204.00 MB
    Ray-tracing:CPU
    OpenGL
    Device:ATI Radeon HD 6750M OpenGL Engine
    Total Memory:512.00 MB
    Shader Model:-
    CUDA
    Driver Version:-
    Devices:-
    Is there any solution for this?
    May 9, 2012 11:40 AM   in reply to adam@blueapplestudio
    Add me to the list with this problem. Here's my GPU info:
    Texture Memory:409.00 MB
    Ray-tracing:CPU
    OpenGL
    Shader Model:-
    CUDA
    Driver Version:-
    Devices:-
    May 9, 2012 3:06 PM   in reply to adam@blueapplestudio
    Plus one.  Mac Pro 3,1 OSX 10.6.8, 32gb RAM.  I add a Ray-Traced 3D pre-comp into a Ray-Traced 3D comp.  The pre-comp shows up and is visible, but when I move the CTI past the pre-comp into section where the comp's own 3D ray-traced layers exist, the machine times out and I get the error:
    After Effects error: Ray-trace 3D: Ray tracer failed to launch.
    ( 5070 :: 0 )
    Texture Memory:818.00 MB
    Ray-tracing:GPU
    OpenGL
    Vendor:NVIDIA Corporation
    Device:NVIDIA Quadro 4000 OpenGL Engine
    Version:2.1 NVIDIA-1.6.37
    Total Memory:2.00 GB
    Shader Model:-
    CUDA
    Driver Version:4.0
    Devices:1 (Quadro 4000)
    Current Usable Memory:559.00 MB (at application launch)
    Maximum Usable Memory:2.00 GB
    May 9, 2012 3:23 PM   in reply to rowlkr
    Now I have removed the pre-comp from the Ray-Traced 3D comp and still getting the error.
    May 9, 2012 10:21 PM   in reply to nesha_le
    Funny thing, on a way slower machine than iMac 2011 (which, as noted above has this raytrace error), macbook pro 15", mid 2010, raytrace works with no problem. GPU info on macbook pro is as follows:
    Texture Memory:200.00 MB
    Ray-tracing:CPU
    OpenGL
    Device:NVIDIA GeForce GT 330M OpenGL Engine
    Version:2.1 NVIDIA-7.18.18
    Total Memory:256.00 MB
    Shader Model:-
    CUDA
    Driver Version:-
    Devices:-
    Adobe, any suggestions? Solutions?
    May 9, 2012 10:30 PM   in reply to SPG_ADB
    Oh yeah, MacPro 1,1 is the one with the problem while a MacBookPro 8,1 works without the error.
    Is there anything worth trying at this point that might solve the problem, or make it go away long enough to use it?
    May 9, 2012 11:26 PM   in reply to Todd_Kopriva
    same errors to me... i am running a MacBookPro OS X 10.7.3 2.2GHz Intel Core i7 GPU is a AMD Radeon HD 6750M
    Thanx for helping
    May 10, 2012 3:12 AM   in reply to ChrisProsser
    Woks great with my macbookpro mid 2011...
    May 10, 2012 3:18 AM   in reply to lehiboo69
    are you running on OS X Lion? What kind of GPU?
    May 10, 2012 4:01 AM   in reply to Migi77
    • Macosx Lion 10.7.4
    • Intel HD Graphics 3000
    • AMD Radeon HD 6770M with 1 Go  GDDR5
    this is for my macbook pro mid 2011 and it works...but very slow.
    On my Imac 27 inches...doesn t work...see the specs above in my former post...
    May 10, 2012 4:19 AM   in reply to lehiboo69
    strange thing... my macbookpro (may 2011) is runnig with the same specs as yours.... but it doesn't work...
    May 10, 2012 5:02 AM   in reply to adam@blueapplestudio
    Re: After Effects error: Ray-traced 3D: Initial Shader compile failed. (5070::0) refers to an incompatible graphics card or GPU device. The solution is to remove the incompatible graphics card or replace with compatible graphics card and re-install the software.
    For me I had to remove a nVidia Tesla C1060 card which is incompatible. My main graphics card is a nVidia Quadro fx 5800 which is compatible. After re-installing After Effects the error message was gone.
    Hope that helps.
    May 10, 2012 7:29 AM   in reply to adam@blueapplestudio
    thanx for the list...but not easy to change a card on an I mac... ;-)
    May 10, 2012 7:30 AM   in reply to adam@blueapplestudio
    No problems using a gtx 470 for fast previews on windows 7, but of course does not support hardware-based raytracing...
    On the mac side, there seems to be no software-only support at all if after effects doesn't like your graphics card.  This needs to be fixed...
    May 10, 2012 8:42 AM   in reply to Adamdanielpalmer
    i have the same problem in my two Macs.
    In MBP 15.4 mid 2011 and ATI with 256 VRAM + iMac 2010 with ATI 512 MB  (8 GB RAM both machines - Lion OSX )
    May 10, 2012 8:47 AM   in reply to john spirou
    Hi Folks,
    Chris from Adobe here.
    @Adamdanielpalmer "On the mac side, there seems to be no software-only support at all if after effects doesn't like your graphics card.  This needs to be fixed..."
    That's not an accurate statement. There are plenty of people (even on this thread) where After Effects detects the incompatible GPU and uses CPU correctly. But clearly it's not working correctly 100% of the time.
    There is some common thing between all your machines that is causing this to fail. One of my engineers spent all day yesterday trying to reproduce this issue, but things were always going to CPU correctly.
    So sorry, no resolution yet as to what is happening.
    Just a wild guess in the dark, are the failing machines possibly upgraded in place from 10.6 -> 10.7?
    --chris
    May 10, 2012 8:52 AM   in reply to ChrisProsser
    My MBP (Which does work) is gaurenteed a fresh Lion install - Shipped with it.
    I'm 95% sure my Mac Pro (Does not work) was a Lion only install using the method of extracting the .dmg image and transferring onto a DVD out of the App Store Package file.
    May 10, 2012 8:54 AM   in reply to ChrisProsser
    Please pardon my frustration...with a new OS about every year I can't imagine how difficult it is to keep software in sync with Apple.
    Yes, We just upgraded from 10.6 to 10.7 a couple days ago...
    May 10, 2012 9:08 AM   in reply to Adamdanielpalmer
    May 10, 2012 9:11 AM   in reply to ChrisProsser
    Most of us  use Lion now (10.7) ... can you (adobe) try to reproduse the errors in a modern machine with Lion ?
Actions
Bookmarked By (2)
