Using Sg with 2 monitors
May 8, 2012 7:12 PM
Tags: #dual_monitors #hdmi
Hello, I have 2 HDMI monitors coming from a Quadro 2000 card on a PC. When I select the "enable 2 monitors" in setup, I lose the video playback in my first monitor, but can't get it to display in the second. I can move Speedgrade to the second monitor and it displays fine, but I can't get it to work in both monitors at the same time (video on one, controls on the other, like Premiere). How can I do this? Do I need to have a high-end SDI nvidia card? Thanks!
    May 9, 2012 2:19 AM   in reply to christopher_n
    When you enable dual display is normal to lose video playback in first monitor. In settings set left field to the width in pixel of main display, and width-height fields to dimensions of second display. That's all.
    May 9, 2012 8:44 AM   in reply to christopher_n
    With dual display enable, the gui is in one monitor and the image in the other, that's as it works. Also make sure the gui monitor is to the left on OS display settings.
    May 9, 2012 8:52 AM   in reply to christopher_n
    If you want GUI on the right you can send the image to the left monitor using "-1920" in display settings. As Manuel already mentioned, moving the scopes to a second monitor is not possible.
    May 12, 2012 6:22 AM   in reply to christopher_n
    Try 0 (zero) in the Left setting.
