fanqijing.businesscatalyst.com
THE "PACKAGING" CANT OPEN, U TRIED IT THOUNSAND TIMES!!!! I LINKED EVERY LINK CORRECTLY...
AND I TRIED PULISH AS HTML.. DOESNT CHANGE ANYTHING OFIT
PS: WHY THIS SOFTWEAR HAS SO MANY PROBLEMS?
It looks like you might be typing in your links instead of using the drop down menu.
If you want to type in links, be sure add ".html" after them
example: PACKAGING.HTML
If you decide to use the drop down menu, it's important to note that once you have typed something incorrect into your hyperlinks it appears under the "Recently Used Links" (and is still incorrect) so you want to avoid using anything that is under that section and instead use the ones found under "Pages"
As it was already mentioned you wrote the page name in the Link field and this doesn't work quite like this. You should use the drop-down and choose from the elements available under "Pages"
If it helps you can also have a look at this very short recording here (the links that Muse recognize are under "Pages", what's under "Recently used links" I actually wrote and they don't work)
Cheers!
North America
Asia Pacific
