CS6 installation asking for proxy password
May 9, 2012 8:01 AM
I am upgrading one of our school PC's from CS3 to CS6.
Everything is downloaded and the installer has begun.
It asks me now to provide a proxy server username and password.
We do use a proxy at school for internet access and this uses NTLM authentication to track the staff and students sites visited by their active directory credentials.
There is no other proxy server username or password...
What should I enter as it won't let me carry on without entering something...
    May 9, 2012 8:15 AM   in reply to BalcarrasIT
    Use the proxy's admin credentials. Not saying that this sounds in any way right, but this seems the quickest fix to what no doubt is a bug of sorts...
    Mylenium
    May 9, 2012 3:17 PM   in reply to BalcarrasIT
    Have you contacted your I.T. department and ask them to enter the proper credentials?  It is expected behavior for our software to access the Internet with CS6 we are doing this to register the product to your Adobe ID. It should also pass that information on so when CS6 checks for updates it will use the same proxy credentials.
    May 9, 2012 3:37 PM   in reply to BalcarrasIT
    The NTLM authentication might be part of the problem.  You should be able to install if you pull the network connection and install in trial mode.  You will then either be given an option to complete an offline activation or perhaps our Adobe Application Manager will have more success once the product is fully installed.
    May 9, 2012 5:03 PM   in reply to BalcarrasIT
    Aye the AAMEE will solve for these type of difficulties.  It is a good thing though, after a fashion, as this helps us work out the kinks on an individual user level before it starts being deployed in the Enterprise environment.
    May 10, 2012 9:58 AM   in reply to BalcarrasIT
    After Effects, Encore, Premiere Pro, and SpeedGrade all require a 64-bit OS to run.  I would recommend customizing your deployment package to not attempt to install these applications on a 32-bit system.
