When I try to supress hyphenation in an arithmetic expression (-64dBVp-p), I select that word then hit shortcut
ESC n s (as the documentation says). A "no hyphenation" marker appears but the word itself disappears. Am I doing something wrong?
Cheers,
JP
I found either a solution or a workaround. David solved the problem of the
disappearing word (<applies dope slap to self>) but the word still broke
at the hyphen.
I then tried changing the hyphen to a true minus sign, (CTRL-Q SHIFT-P)
but that didn't work either-- the word broke after the minus sign.
The problem went away after I did Format>Document>Text Options and removed
both the hyphen and the minus sign from the "Allow Line Breaks After" field.
Cheers,
JP
North America
Asia Pacific
