Fuzzy_Barsik wrote:
As I said earlier, I can't check adjustment layer behaviour for now. Hence I can't argue for sure whether effects on adjustment layer for 'upper' camera angle will be calculated when you switch to a 'lower' camera angle layer in multicam or not.
As soon as this render is done I'll try it ![]()
Jim, can you see 'invisible' adjustment layer per se? Have you ever played with two adjustment layers laying one on another so as to get e.g. 'instant sex' effect? Was the lower adjustment layer affected by upper one?
In PrPro CS6 scenario why adjustment layer for lower camera angle should be taken into account at all since it is covered by completely opaque upper camera angle layer as well?
We..... I can tell you they don't do what you think they do.
As I expected, each adjustment layer occupies a video track in a multicam sequence. So, if you had 3 tracks and added an adjustment layer sandwich you now have 6 tracks in the multicam monitor. Adding a three way colour corrector to each of the adjustment layers does absolutly NOTHING to the video because it's not selected as part of the multicam and it therefore is itself 'invisible'.
You can of source select the adjustment layer AS video and end up with some nicely tinted black frames ![]()
You have to add the adjustment layer to the final multicam sequence, which of course means slicing it along with each angle.
North America
Asia Pacific
