vaughanseybah
Exit code 7 when installing CS5.5
May 9, 2012 5:39 PM
I'm having the following error message when installing 5.5
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 3 error(s), 3 warning(s)
WARNING: DW031: Payload:{6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
WARNING: DW031: Payload:{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 has been updated and has been selected for repair. The patch {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 will be uninstalled now.
ERROR: DW020: Found payload conflicts and errors:
ERROR: DW020:  - Adobe Photoshop CS5.1 Core depends on AdobeColorPhotoshop CS5.5 to be installed.
ERROR: DW020:  - Adobe Photoshop CS5.1 Core depends on AdobeColorVideoProfilesCS CS5.5 to be installed.
FATAL: DW020: Conflicts were found in the selected payloads. Halting installation.
I can get everything except Illustrator to install. I have tried the Support Advisor and all the uninstall advice without success.
    May 10, 2012 3:40 AM   in reply to vaughanseybah
    Please try the below suggestions:
    Solution 1: Rename the following folders on your machine:
    '/Library/ColorSync/Profiles/Profiles'
    '/Library/ColorSync/Profiles/Recommended'
    Solution 2: Rename the following files:
    '/Library/Application Support/Adobe/caps/Media_db.db'
    '/Library/Application Support/Adobe/caps/pdb.db'
    Make sure you dont touch caps.db under the same folder. Now run the installer again. Let me know if you need more help.
    Aug 16, 2012 1:04 PM   in reply to Arpit Kapoor
    These steps will work 100%.
    Thank you Arpit.
