FlashKatt
Graphic moves tho it's position is numerically the same
May 11, 2012 2:34 PM
I have a graphic..a bit of type imported as an AI graphic, which moves when I play the animation in Flash (by hitting the Return key).
I check its position before and after I see it move; no change in the position. When I publish, this same element does not move, which is good..but...
..the fact that it moves in Flash throws the accuracy of the feedback...is it moving or isn't it? sort of thing..
anyone know what the cause and fix for this would be?
Thank you!
kat
    May 11, 2012 3:13 PM   in reply to FlashKatt
    It is not clear what you are doing or what the problem is, but it sounds like maybe the contents of whatever container you are checking the position of are what is moving, not the container itself.
