ctakah27
CS6 render time
May 11, 2012 10:21 PM
Ladies & gentlemen, I work on a 2 y.o. top of the line imac, 16G of RAM running snow leopard. A comp takes 15 min to render in 5.5 and same comp when opened in CS6 takes 40 minutes to render (same settings - 1080, photojpeg).
Mmmmm?
    May 12, 2012 7:49 PM   in reply to ctakah27
    Ummm...
    Did you make sure to set your Memory settings to use the desired ammount of ram?
    Were you using different GPU settings/prefs in CS5.5?
    May 15, 2012 12:26 AM   in reply to ctakah27
    You said that you have 16GB of RAM installed, but this shows that you only have 4GB.
    Jun 6, 2012 12:05 PM   in reply to ctakah27
    ctakah27 wrote:
    I understand that with 4GB of ram I won't be making the next prometheus movie, but it would be nice to get the most out of it...
    ....and that would be to turn multiprocessing OFF, and leave it off.  In AE terms, 4 gigs is enough to run the operating system and AE alone.  It doesn't get you efficient use of multiprocessing, but it does give you headaches if you try to use multiprocessing.
