Exley22
Dreamweaver Fluid Grid and Twitter Bootstrap
May 13, 2012 3:23 PM
Tags: #dreamweaver #cs6 #twitter_bootstrap #fluid_grid #responsive_design
Does anyone know if it's possible to graft the Twitter Bootstrap styling, elements and functioning onto the Fluid Grid in Dreamweaver CS6? If so how?
I think it would be great to be able to have the ease of manipulating the rows and columns using the Fluid Grid and have all the cool styling and all from Twitter Bootstrap.
    May 19, 2012 12:33 PM   in reply to Exley22
    I don't see why you couldn't add it between BOILERPLATE.CSS and your current FLUIDGRID.CSS.  NOTE: FluidGrid.css must come after everything else.
              <link href="Scripts/boilerplate.css" rel="stylesheet" type="text/css">
              [INSERT BOOTSTRAP HERE]
              <link href="FluidGrid.css" rel="stylesheet" type="text/css">
    Linking HTML to external CSS in Dreamweaver
    http://alt-web.com/DEMOS/DW-Link-Stylesheet.shtml
    In case you don't already know, there is a Forum for Dreamweaver  questions:
    http://forums.adobe.com/community/dreamweaver/dreamweaver_general?view =discussions
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    Aug 11, 2012 11:36 AM   in reply to Nancy O.
    I discovered when trying to get bootstrap code for fluid grid layouts to display properly in Dreamweaver that the following code is not understood by the HTML editor in Dreamweaver:
    .row [class*="col"] {
      display: inline;
      float: left;
      width: 100%;
      min-height: 28px;
      margin-left: 1.127659574%;
      *margin-left: 1.0744680846382977%;
      -webkit-box-sizing: border-box;
         -moz-box-sizing: border-box;
          -ms-box-sizing: border-box;
    Instead of the shorthand .row [class*="col"] you have to list each grid column like this:
    .col1,
    .col2,
    .col3,
    .col4,
    .col5,
    .col6,
    .col7,
    .col8,
    .col9,
    .col10,
    .col11,
    .col12
        display: inline;
      float: left;
      width: 100%;
      min-height: 28px;
      margin-left: 2.127659574%;
      *margin-left: 2.0744680846382977%;
    Aug 18, 2012 10:12 AM   in reply to edmdgomez
    DW's Design View is not 100% reliable.  For best results use Live View or Preview in Browsers to test your layouts.
    Nancy O.
    Aug 18, 2012 10:23 AM   in reply to Nancy O.
    Previewing in the browser is a given but putting a page together is much easier if the page looks right in the editor. Most grid systems don't work in Dreamweaver Design View so I was pleased when I was able to get Bootstrap to work because it is such a good framework.
    Oct 4, 2012 8:11 PM   in reply to edmdgomez
    I have exactly the same problem with DW CS6. Most frameworks do not show correctly in design view. Foundation doesn't show properly, neither does Bootstrap. Your solution didn't work for me. Where do I place it in the CSS? In bootstrap itself, in my own CSS? What is the signifance of the *margin-left vs margin-left above?
    To the Abode people: I did find a solution that does work. But neither you and me will like that: Kompozer works excellent. I don't like it, because many years of experience working with DW go down the drain. And you don't because loose a customer.
    Surely you guys are able to come with with a better answer than 'our current flagship is partly 5 years out of date'. Is it that difficult to make an update so it works? Imagine Ford says: "our current top of the line model has an engine of a T-Ford, we apologize for any inconvience." Would you still buy that Ford? Or perhaps find a different car?
    I'm pretty certain it is a border issue. I had that in the past with a simpler framework, setting the borders to zero solved it. The problem here is that Foundation and Bootstrap will fall apart if I do that.
    Oct 4, 2012 9:57 PM   in reply to Gany_M
    Here is the complete grid css file that I'm using. It is modified from the original bootstrap. Different class names. It's wrapped in a media query so that the grid only applies above 768px. It gives you a 12 grid system.
    @media only screen and (min-width: 768px) {
    /* Grids only applied to desktop and tablet
    .col1,
    .col2,
    .col3,
    .col4,
    .col5,
    .col6,
    .col7,
    .col8,
    .col9,
    .col10,
    .col11,
    .col12
        display: inline;
      float: left;
      width: 100%;
      min-height: 28px;
    .row [class*="col"]:first-child {
      margin-left: 0;
    .row .col12 {
      width: 99.99999998999999%;
      *width: 99.94680850063828%;
    .row .col11 {
      width: 91.489361693%;
      *width: 91.4361702036383%;
    .row .col10 {
      width: 82.97872339599999%;
      *width: 82.92553190663828%;
    .row .col9 {
      width: 74.468085099%;
      *width: 74.4148936096383%;
    .row .col8 {
      width: 65.95744680199999%;
      *width: 65.90425531263828%;
    .row .col7 {
      width: 57.446808505%;
      *width: 57.3936170156383%;
    .row .col6 {
      width: 48.93617020799999%;
      *width: 48.88297871863829%;
    .row .col5 {
      width: 40.425531911%;
      *width: 40.3723404216383%;
    .row .col4 {
      width: 31.914893614%;
      *width: 31.8617021246383%;
    .row .col3 {
      width: 23.404255317%;
      *width: 23.3510638276383%;
    .row .col2 {
      width: 14.89361702%;
      *width: 14.8404255306383%;
    .row .col1 {
      width: 6.382978723%;
      *width: 6.329787233638298%;
    /* Prefix Extra Space >> 12 Columns
    .prefix_1 {
        padding-left: 8.333%;
    .prefix_2 {
        padding-left: 16.667%;
    .prefix_3 {
        padding-left: 25.0%;
    .prefix_4 {
        padding-left: 33.333%;
    .prefix_5 {
        padding-left: 41.667%;
    .prefix_6 {
        padding-left: 50.0%;
    .prefix_7 {
        padding-left: 58.333%;
    .prefix_8 {
        padding-left: 66.667%;
    .prefix_9 {
        padding-left: 75.0%;
    .prefix_10 {
        padding-left: 83.333%;
    .prefix_11 {
        padding-left: 91.667%;
    /* Suffix Extra Space >> 12 Columns
    .suffix_1 {
        padding-right: 8.333%;
    .suffix_2 {
        padding-right: 16.667%;
    .suffix_3 {
        padding-right: 25.0%;
    .suffix_4 {
        padding-right: 33.333%;
    .suffix_5 {
        padding-right: 41.667%;
    .suffix_6 {
        padding-right: 50.0%;
    .suffix_7 {
        padding-right: 58.333%;
    .suffix_8 {
        padding-right: 66.667%;
    .suffix_9 {
        padding-right: 75.0%;
    .suffix_10 {
        padding-right: 83.333%;
    .suffix_11 {
        padding-right: 91.667%;
    /* Push Space >> 12 Columns
    .push_1 {
        left: 8.333%;
    .push_2 {
        left: 16.667%;
    .push_3 {
        left: 25.0%;
    .push_4 {
        left: 33.333%;
    .push_5 {
        left: 41.667%;
    .push_6 {
        left: 50.0%;
    .push_7 {
        left: 58.333%;
    .push_8 {
        left: 66.667%;
    .push_9 {
        left: 75.0%;
    .push_10 {
        left: 83.333%;
    .push_11 {
        left: 91.667%;
    /* Pull Space >> 12 Columns
    .pull_1 {
        left: -8.333%;
    .pull_2 {
        left: -16.667%;
    .pull_3 {
        left: -25.0%;
    .pull_4 {
        left: -33.333%;
    .pull_5 {
        left: -41.667%;
    .pull_6 {
        left: -50.0%;
    .pull_7 {
        left: -58.333%;
    .pull_8 {
        left: -66.667%;
    .pull_9 {
        left: -75.0%;
    .pull_10 {
        left: -83.333%;
    .pull_11 {
        left: -91.667%;
    /* Clear Floated Elements
    /* http://sonspring.com/journal/clearing-floats */
    .clear {
        clear: both;
        display: block;
        overflow: hidden;
        visibility: hidden;
        width: 0;
        height: 0;
    /* http://perishablepress.com/press/2008/02/05/lessons-learned-concerning -the-clearfix-css-hack */
    .row:before,
    .row:after {
      display: table;
      line-height: 0;
      content: "";
    .row:after {
      clear: both;
    .row {
        display: inline-block;
    * html .row {
        height: 1%;
    .row {
        display: block;
    .row .first {
        margin-left: 0;
    Oct 9, 2012 2:38 AM   in reply to edmdgomez
    Hi Ed,
