CQ5
Maven plugin for managing CQ5 packages
May 14, 2012 11:59 AM
Here's some new documentation that explains how to use the Content Package Maven plugin. You can package and install content from your maven build...for example, in your POM, add goals for package creation and installation to automatically deploy the OSGi bundle that was built. You can perform other package management tasks on remote servers, like rebuild packages,  and list, uninstall, and remove them.
http://dev.day.com/docs/en/cq/current/core/how_to/how_to_use_the_vltto ol/vlt-mavenplugin.html
scott
    Oct 3, 2012 11:47 AM   in reply to Scott Brodersen
    When I build my pom as mvn content-package:build, I get following error:
    [ERROR] No plugin found for prefix 'content-package' in the current project and in the plugin groups [org.apache.maven.plugins, org.codehaus.mojo] available from the repositories [
    local (C:\Users\gxoshre\.m2\repository), internal (http://localhost:9090/archiva/repository/internal/)] -> [Help 1]
    I have also uploaded the plug in as in my local Archiva:
    Repository      internal
    Group ID      com.day.jcr.vault
    Artifact ID      content-package-maven-plugin
    Version      0.0.18
    Packaging      maven-plugin
    POM Snippet
        <plugin>
          <groupId>com.day.jcr.vault</groupId>
          <artifactId>content-package-maven-plugin</artifactId>
          <version>0.0.18</version>
        </plugin>
    Any pointers? Thanks in advance.
  • Justin Edelson
    Nov 24, 2010
    Oct 3, 2012 11:55 AM   in reply to cqlearner
    cqlearner-
    It is more typical to attach the Content Package Maven plugin to the Maven lifecycle and then use 'mvn package'.
    If you want to use the plugin from the command line without prefix, you need to add the groupId com.day.jcr.vault to your settings.xml file. See http://maven.apache.org/settings.html#Plugin_Groups
    Regards,
    Justin
    Oct 3, 2012 12:56 PM   in reply to Justin Edelson
    Thank you so much for prompt reply!!
    I am new to this so I am bit confused.
    Would it be possible for you to check my pom file? And let me know if the configuration looks Ok?
    Command used: mvn clean package content-package:install -P felix-deploy
    Setting.xml
    <?xml version="1.0" encoding="UTF-8"?>
    <settings xmlns="http://maven.apache.org/SETTINGS/1.0.0"
        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
        xsi:schemaLocation="http://maven.apache.org/SETTINGS/1.0.0 http://maven.apache.org/xsd/settings-1.0.0.xsd">
        <pluginGroups>
            <pluginGroup>content-package-maven-plugin</pluginGroup>
        </pluginGroups>
        <proxies />
        <servers>
            <server>
                <id>snapshots</id>
                <username>cqadmin</username>
                <password>internal1</password>
            </server>
            <server>
                <id>internal</id>
            </server>
        </servers>
        <mirrors>
            <mirror>
                <id>internal</id>
                <url>http://localhost:9090/archiva/repository/internal/</url>
                <mirrorOf>*</mirrorOf>
            </mirror>
        </mirrors>
        <profiles>
            <profile>
                <id>adobe-public</id>
                <activation>
                    <activeByDefault>false</activeByDefault>
                </activation>
                <properties>
                    <releaseRepository-Id>adobe-public-releases</releaseRepository-Id>
                    <releaseRepository-Name>Adobe Public Releases</releaseRepository-Name>
                    <releaseRepository-URL>
                        http://repo.adobe.com/nexus/content/groups/public/com/day/cq/wcm/cq-co ntent/</releaseRepository-URL>
                </properties>
                <repositories>
                    <repository>
                        <id>adobe-public-releases</id>
                        <name>Adobe Public Repository</name>
                        <url>http://repo.adobe.com/nexus/content/groups/public</url>
                        <releases>
                            <enabled>true</enabled>
                            <updatePolicy>never</updatePolicy>
                        </releases>
                        <snapshots>
                            <enabled>false</enabled>
                        </snapshots>
                    </repository>
                </repositories>
                <pluginRepositories>
                    <pluginRepository>
                        <url> http://repo.adobe.com/nexus/content/groups/public/com/day/cq/wcm/cq-co ntent/</url>
                        <releases>
                        </releases>
                        <snapshots>
                        </snapshots>
                    </pluginRepository>
                </pluginRepositories>
            </profile>
        </profiles>
    </settings>
    POM.xml
    <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
        xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
        <modelVersion>4.0.0</modelVersion>
        <groupId>common</groupId>
        <artifactId>common-ui</artifactId>
        <version>0.0.1</version>
        <name>common-ui</name>
        <properties>
            <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
            <!-- timestamp property used when filtering files from META-INF path -->
            <maven.build.timestamp.format>yyyy-MM-dd'T'HH:mm:ss.SZ</maven.build.t imestamp.format>
            <timestamp>${maven.build.timestamp}</timestamp>
            <cq5.package.group>Common UI</cq5.package.group>
            <cq5.app.name>common-ui</cq5.app.name>
        </properties>
        <profiles>
            <profile>
                <id>felix-deploy</id>
                <build>
                    <plugins>
                        <plugin>
                            <version>0.0.19</version>
                            <configuration>
                                <failOnError>true</failOnError>
                                <packageFile>
                                    ${project.artifactId}-${project.version}-cq5-package.zip
                                </packageFile>
                                <targetURL>http://localhost:4502/crx/packmgr/service.jsp</targetURL>
                            </configuration>
                            <executions>
                                <execution>
                                    <goals>
                                        <goal>package</goal>
                                    </goals>
                                </execution>
                            </executions>
                        </plugin>
                    </plugins>
                </build>
            </profile>
        </profiles>
        <build>
            <plugins>
                <plugin>
                    <!-- Assembly plugin used to make cq5 package zip file -->
                    <artifactId>maven-assembly-plugin</artifactId>
                    <version>2.3</version>
                    <configuration>
                        <builtContentDirectory>jcr_root</builtContentDirectory>
                    </configuration>
                    <executions>
                        <execution>
                            <id>make-assembly</id>
                            <phase>package</phase>
                            <goals>
                                <goal>single</goal>
                            </goals>
                        </execution>
                    </executions>
                </plugin>
            </plugins>
            <resources>
                <resource>
                    <directory>src/main/content</directory>
                    <includes>
                        <include>**/*.*</include>
                    </includes>
                </resource>
            </resources>
        </build>
    </project>
    ERROR:
    C:\workspace-aaa-eris\wms-cms-common-ui>mvn clean package content-package:install -P felix-deploy
    [INFO] Scanning for projects...
    [WARNING] Failed to retrieve plugin descriptor for com.day.jcr.vault:content-package-maven-plugin:0.0.19: Invalid plugin descriptor for com.day.jcr.vault:content-package-maven-plug
    in:0.0.19  (C:\Users\gxoshre\.m2\repository\com\day\jcr\vault\content-package-ma ven-plugin\0.0.19\content-package-maven-plugin-0.0.19.jar), Plugin's descriptor contains the wrong ve
    rsion: 0.0.16
    Downloading: http://localhost:9090/archiva/repository/internal/org/codehaus/mojo/ma ven-metadata.xml
    Downloading: http://localhost:9090/archiva/repository/internal/content-package-mave n-plugin/maven-metadata.xml
    Downloading: http://localhost:9090/archiva/repository/internal/org/apache/maven/plu gins/maven-metadata.xml
    Downloaded: http://localhost:9090/archiva/repository/internal/org/apache/maven/plu gins/maven-metadata.xml (11 KB at 0.7 KB/sec)
    Downloaded: http://localhost:9090/archiva/repository/internal/org/codehaus/mojo/ma ven-metadata.xml (21 KB at 1.4 KB/sec)
    [INFO] --------------------------------------------------------------------- ---
    [INFO] BUILD FAILURE
    [INFO] Total time: 15.148s
    [INFO] Finished at: Wed Oct 03 12:34:25 MST 2012
    [INFO] Final Memory: 4M/15M
    [ERROR] No plugin found for prefix 'content-package' in the current project and in the plugin groups [content-package-maven-plugin, org.apache.maven.plugins, org.codehaus.mojo] ava
    ilable from the repositories [local (C:\Users\gxoshre\.m2\repository), internal (http://localhost:9090/archiva/repository/internal/)] -> [Help 1]
    [ERROR]
    [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
    [ERROR] Re-run Maven using the -X switch to enable full debug logging.
    [ERROR]
    [ERROR] For more information about the errors and possible solutions, please read the following articles:
    [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/NoPluginFoundForPrefi xException
  • Justin Edelson
    Nov 24, 2010
    Oct 3, 2012 1:15 PM   in reply to cqlearner
    As I said, you need to add the groupId com.day.jcr.vault to your settings.xml file. See http://maven.apache.org/settings.html#Plugin_Groups
    I would recommend using the content-package-maven-plugin to build your project rather that just deploy it. I see you are using the assembly plugin now. This will work, but the content-package-maven-plugin is designed for this specific use case whereas the assembly plugin is a generalized tool.
    Check out http://dev.day.com/docs/en/cq/current/core/how_to/how_to_use_the_vltto ol/vlt-mavenplugin.html#Using%20Archetypes%20To%20Generate%20CQ%20Proj ects for some sample project setups.
    Oct 4, 2012 7:40 AM   in reply to Justin Edelson
    Hi Justin,
    I am still stuck
    I am following the documentation and couldn't even complete this section (http://dev.day.com/docs/en/cq/current/core/how_to/how_to_use_the_vltto ol/vlt-mavenplugin.html#ls)
    When I run mvn content-package:ls I get this error:
    [ERROR] No plugin found for prefix 'content-package' in the current project and in the plugin groups [content-package-maven-plugin, com.day.jcr.vault, maven-assembly-plugin, org.ap
    ache.maven.plugins, org.codehaus.mojo] available from the repositories [local (C:\Users\gxoshre\.m2\repository), internal (http://localhost:9090/archiva/repository/internal/)] -> [
    I have the plugin in local directory as well as in archiva:
    C:\Documents and Settings\gxoe\.m2\repository\com\day\jcr\vault\content-package-maven- plugin\0.0.16\content-package-maven-plugin-0.0.16.jar
    Repositoryinternal
    Group IDcom.day.jcr.vault
    Artifact IDcontent-package-maven-plugin
    Version0.0.16
    Packagingmaven-plugin
    POM Snippet
        <plugin> <groupId>com.day.jcr.vault</groupId> <artifactId>content-package-maven-plugin</artifactId> <version>0.0.16</version> </plugin>
    Oct 4, 2012 7:46 AM   in reply to cqlearner
    you may want to check out the maven archetype for cq on cqblueprints at
    http://www.cqblueprints.com/xwiki/bin/view/BluePrints/TheCQProjectMaven+Archetype
    for your project setup. There are subprojects for services, packages,
    etc available. There is also a maven setup somewhere on the adobe site
    available.
    Ruben
  • Justin Edelson
    Nov 24, 2010
    Oct 4, 2012 8:01 AM   in reply to cqlearner
    content-package-maven-plugin and org.apache.maven.plugins are not groupIds and do not belong in the list of pluginGroups.
    If that doesn't resolve the issue, I don't know what it could be offhand. You may need to fully qualify the plugin:
    mvn com.day.jcr.vault:content-package-maven-plugin:ls
    Regards,
    Justin
    Oct 4, 2012 2:55 PM   in reply to Justin Edelson
    Finally figured it out. I had the configuration correctly but when I uploaded the "content-package-maven-plugin-0.0.16.jar" to archiva I didnot upload the .pom file. Everything works now !!  Special thanks to you.
    Oct 23, 2012 1:16 PM   in reply to Justin Edelson
    Hi Justin,
    Can content-package-maven-plugin support multile targetURL deployment? I would like to deploy the zip file to author and publish instance at the same time.
    <plugin>
                    <configuration>
                        <name>test</name>
                        <filterSource>
                            src/main/content/META-INF/vault/filter.xml
                        </filterSource>
                    </configuration>
                     <executions>
                        <execution>
                            <goals>
                            </goals>
                        </execution>
                    </executions>
                </plugin>
  • Justin Edelson
    Nov 24, 2010
    Oct 23, 2012 1:19 PM   in reply to cqlearner
    You need to define multiple executions of the plugin.
    Oct 23, 2012 2:04 PM   in reply to Justin Edelson
    Sorry I am new to maven, do you have example?  I tried following and it only executed 1st one.
    Thanks in advance
    <plugins>
                <plugin>
                    <executions>
                        <execution>
                            <goals>
                            </goals>
                            <configuration>
                                <name>b2c-ui</name>
                                <filterSource>
                                </filterSource>
                            </configuration>
                        </execution>
                        <execution>
                            <goals>
                            </goals>
                            <configuration>
                                <name>b2c-ui</name>
                                <filterSource>
                                </filterSource>
                               <targetURL>http://localhost:4503/crx/packmgr/service.jsp</targetURL>
                            </configuration>
                        </execution>
                    </executions>
                </plugin>
            </plugins>
  • Justin Edelson
    Nov 24, 2010
    Oct 23, 2012 3:14 PM   in reply to Justin Edelson
    Thank you for the prompt respose.
    I did what you suggested following the link you provided but it only executes once.
    <plugin>
                    <executions>
                        <execution>
                        <id>execution1</id>
                            <goals>
                            </goals>
                            <configuration>
                                <name>b2c-ui</name>
                                <filterSource>
                                </filterSource>
                            </configuration>
                        </execution>
                        <execution>
                         <id>execution2</id>
                            <goals>
                            </goals>
                            <configuration>
                                <name>b2c-ui</name>
                                <filterSource>
                                </filterSource>
                            </configuration>
                        </execution>
                    </executions>
                </plugin>
  • Justin Edelson
    Nov 24, 2010
    Oct 23, 2012 5:03 PM   in reply to cqlearner
    What the configuration above says is that during the package phase, execute the package goal twice.
    In general, you would be best served by binding the install goal of the content-package-maven-plugin to the install phase and then executing
    mvn clean install
    I actually prefer to do this with profiles. See https://gist.github.com/3942776 for an example syntax.
    Using this, if I want to install just to author, I do
    mvn -PautoInstallPackageAuthor clean install
    Just publish:
    mvn -PautoInstallPackagePublish clean install
    Both:
    mvn -PautoInstallPackageAuthor,autoInstallPackagePublish clean install
    Oct 24, 2012 7:44 AM   in reply to Justin Edelson
    Awesome!! Thanks so much.
