Replies 1 2 3 2 Previous Next
    Jun 25, 2012 8:34 AM   in reply to jamesroche
    After setting the publishing dates of the two renditions again it worked.
    Seems that there was something clogged in the publishing pipeline.
    So the reason was not the Viewer Builder.
    Jun 25, 2012 9:30 AM   in reply to jamesroche
    I've received a number of notes from users with the same problem. For renditions to function, the following fields must be precisely the same:
    1. Folio Title
    2. Product ID
    3. Publication Date
    Many users see their confusion in the publication date requirement, because our UI only shows the date but not the time. If you are creating multiple files for renditions, it is a requirement to manually set the publication date so it is consistent. If you rely on the default date, you will have problems with subscriptions because the timestamps are different. Here's an example of one of the users' accounts I've just investigated:
    <publicationDate>2012-06-13T10:23:37Z</publicationDate>
    <publicationDate>2012-06-12T22:00:00Z</publicationDate>
    These dates appear as the same in the Folio Producer UI, but are clearly not the same. The fix for this issue is to manually set the dates to the same value, and update the content with "Update Content" checked.
    Thanks.
Actions
