Adding text to 'on mouse' image boxes
May 15, 2012 9:43 AM
Me again I'm afraid. After completing the web page below I thought it might be better to have a line of explanatory text for each image shown as the drop down menu is 'rolled' over...
Each of the items in the menu on the right reveal an alternate image and for the life of me I can't see where to add a simple line or two of text to either go under or to the right of the image (if I move images to the left!
Anyone have a way to add the text? I can see that you can add text in the 'Behaviours' - Is this where I should be going?
Code below for this area of the page :
CSS :
#imageview {
          height: 476px;
          width: 476px;
          position: relative;
          left: 138px;
          top: 30px;
          float: left;
          background-repeat: no-repeat;
          background-position: center center;
HTML :
<body onload="MM_preloadImages('Images/services_adverts.jpg','Images/servic es_brochures.jpg','Images/services_carto.jpg','Images/services_catalog ues.jpg','Images/services_destoprint.jpg','Images/services_digiIllustr ate.jpg','Images/services_branding.jpg','Images/services_packaging.jpg ','Images/services_reports.jpg','Images/services_digiretouch.jpg','Ima ges/services_techmanuals.jpg','Images/services_webdesign.jpg')">
<div id="wrapper">
<div id="header panel"><img src="Images/handprint_panel.jpg" alt="header" width="960" height="190" border="0" usemap="#Map" />
  <ul id="MenuBar1" class="MenuBarHorizontal">
    <li><a class="MenuBarItemSubmenu" href="#">SERVICES</a>
      <ul class="stay">
        <li onmouseover="MM_swapImage('Image1','','Images/services_adverts.jpg',1 )"><a href="#">advertising</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_brochures.jpg' ,1)" onmouseout="MM_swapImgRestore()">brochures</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_carto.jpg',1)" onmouseout="MM_swapImgRestore()">cartography</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_catalogues.jpg ',1)" onmouseout="MM_swapImgRestore()">catalogues</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_destoprint.jpg ',1)" onmouseout="MM_swapImgRestore()">design to print</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_digiIllustrate .jpg',1)" onmouseout="MM_swapImgRestore()">illustration</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_branding.jpg', 1)" onmouseout="MM_swapImgRestore()">logos and branding</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_packaging.jpg' ,1)" onmouseout="MM_swapImgRestore()">packaging</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_reports.jpg',1 )" onmouseout="MM_swapImgRestore()">reports</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_digiretouch.jp g',1)" onmouseout="MM_swapImgRestore()">retouching</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_techmanuals.jp g',1)" onmouseout="MM_swapImgRestore()">technical manuals</a></li>
        <li><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_webdesign.jpg' ,1)" onmouseout="MM_swapImgRestore()">web design</a></li>
      </ul>
    </li>
    <li><a href="contact.html">CONTACT</a></li>
    <li><a href="history.html">HISTORY</a></li>
    <li><a href="profile.html">PROFILE</a></li>
    <li><a href="index.html">HOME</a></li>
    <div id="imageview"><img src="Images/services_adverts.jpg" width="440" height="440" border="18" id="Image1" />
    </div>
This works fine already and I really appreciate being able to include some text! If it means adding a separate div box for each alternate rollover/image change then how do I link said div to the onmmouse/onmouseout....
Over to you gurus!
    May 15, 2012 9:51 AM   in reply to Monochrome24
    Add a title attribute to each of your anchor tags.
    Change this:
    <a href="#"
    to this:
    <a title="some descriptive text goes here" href="#"
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    http://twitter.com/altweb
    http://alt-web.blogspot.com/
    May 16, 2012 8:37 AM   in reply to Monochrome24
    In my solution, an ordinary tooltip of text appears on mouseover.   Preview in browsers to test.
    If you want something dynamic and you're using CSS6, look at CSS Transitions.
    http://tv.adobe.com/watch/learn-dreamweaver-cs6/using-the-css-transiti ons-panel/
    Nancy O.
    May 17, 2012 8:36 AM   in reply to Monochrome24
    Can you put the website online somewhere so we can dig into it and try and help you out?
    May 17, 2012 9:59 AM   in reply to Monochrome24
    We're also struggling without the ability to view the page online.
    Where do you eventually plan to host it on the web?
    May 17, 2012 10:11 AM   in reply to Monochrome24
    You can try adding a setTextofContainer behaviour to your existing swap image behaviour for each link.
    Add a <div> container under the 'imageview' <div> as below and position it using css. Then select each link individually and go>Windows>Behaviours>Click plus icon> select Set Text>Set Text of Container. Choose 'caption' from the dropmenu and insert your caption into the box. Save and repeat for your other links.
    <div id="imageview"><img src="Images/services_adverts.jpg" width="440" height="440" style="border-bottom:48px" id="Image1" /></div>
    <div id="caption">caption goes here</div>
    May 17, 2012 10:58 AM   in reply to Monochrome24
    Ultimately, you need to find permanent web hosting.
    In the meantime, this is free:
    http://www.000webhost.com/
    CSS Disjointed Rollovers (view source to see the code):
    alt-web.com/DEMOS/CSS-Image-Viewer.shtml
    Nancy O.
    May 30, 2012 9:51 AM   in reply to Monochrome24
    Move the MM_swapImage behaviours onto the anchor tag and the MM_setTextOfLayer behaviour onto the <li> tag (see below)
    <li onmouseover="MM_setTextOfLayer('explanation','','put descriptive text here')"><a href="#" onmouseover="MM_swapImage('Image1','','Images/services_adverts.jpg',1 )">advertising</a></li>
    Jun 13, 2012 3:23 AM   in reply to Monochrome24
    Change this line:
    <li><a href="#" onclick="MM_goToURL('parent','ordering.html');return document.MM_returnValue" onmouseover="MM_swapImage('Image1','','Images/ordering_out.jpg',1)">s ervices ordering page</a></li>
    To this:
    <li><a href="ordering.html" target="_parent" onmouseover="MM_swapImage('Image1','','Images/ordering_out.jpg',1)">s ervices ordering page</a></li
    Jun 13, 2012 4:36 AM   in reply to Monochrome24
    Can you upload the page somewhere or can you post the whole of the pages code here so I can take a look and see what is happening?
    Jun 18, 2012 7:45 AM   in reply to Monochrome24
    Change 'services ordering page' <li> to as below:
    <li onmouseover="MM_setTextOfLayer('explanation','','')"><a href="ordering.html" target="_parent" onmouseover="MM_swapImage('Image1','','Images/ordering_out.jpg',1)">s ervices ordering page</a></li>
    Jun 18, 2012 10:02 AM   in reply to Monochrome24
    Monochrome24 wrote:
    Perfect as usual osgood! Not knowing code in depth does placing the 'MM_setText...' within the <li> make it invisible or something similar then?
    This code - onmouseover="MM_setTextOfLayer('explanation','','')" - just swaps the description to nothing when you mouse over the words 'service ordering page'
    Jun 20, 2012 5:29 PM   in reply to Monochrome24
    Free hosting is not a substitute for paid hosting.    You get what you pay for.
    000 is a short term, free site to use until you procure permanent  hosting someplace else.
    Reputable paid hosts (in no particular order).
    • InMotion
    • Lunarpages
    • Pair Networks
    • Dreamhost
    Web Hosting Reviews
    http://www.whoishostingthis.com/hosting-reviews/
    Good luck with your project,
    Nancy O.
    Aug 31, 2013 9:04 PM   in reply to Monochrome24
    Free hosting always has advertisements or not all the options paid hosting has. Most the time paid hosting give you free .com domains when you sign up for the first time.
    If you're looking for reputable paid hosts.
    • Godaddy
    • Hostgator
    • Justhost
    • Fatcow
    Check out Web Hosting Coupons and Promos:
    http://sitediscounters.com/category/coupons/
    Hope you find what you're looking for!
