susanyeisert
Arrange document drop down menu doesn't work
May 16, 2012 6:37 AM
Tags: #pse10
I'm using Mac 10.7 and elements 10. I turned on allow floating documents in preferences. The arrange document dropdown menu doesn't work. I've tried it with 4 open photos. I can tile photo by going to window-image tile only.
    May 16, 2012 9:54 AM   in reply to susanyeisert
    The arrange menu is for tabs. If you want to arrange image windows that way, go to window>images>consolidate all to tabs and it should work.
    May 16, 2012 3:39 PM   in reply to susanyeisert
    There is nothing you can do about the File Open window. That is an OS X window, not a PSE window.
    I would delete your PSE preferences--you are sure you are choosing an arrangement for the exact number of open tabs you have? If so, quit the editor then relaunch it while holding command+shift+option. Keep the keys down till you see a window asking if you want to delete the settings file. You do.
