In Illustrator CS6 - Cloud - there's an annoying box floating above my canvas in the upper left hand corner. It is a transparent fill with a black stroke and a dark outer glow.
I've tried turning off every palette and window view, yet it still appears "above" the canvas window. It goes away when the application loses focus but then returns after the application is brought to the foreground. This has to be a bug? Any ideas?
Mac Lion + Macbook Pro + 8GB + CS6 Cloud + Illustrator
Screen Captures attached...
thanks,
mark
Good recommendations, but removing the preferences and fixing permission issues did nothing. Filled out a bug report and now it's time to wait...
Removing the folders called "workspaces" and "modified workspaces" fixed the issue! Thanks!
~/Library/Preferences/Adobe Illustrator CS6 Settings/en_US/
There is another workaround in which you need not loose your workspace:
I have seen this happening on closing the Application Bar when it is floating, hence to get rid of this follow the following step:
- From Windows Menu Turn on "Application Bar'
If you want to keep the application bar closed, Move it above the control panel and drop it after the blue highlight is shwon so that it gets docked there, now you can close it from the window menu.
I already posted this on its own thread but Ijust noticed that there is an update for all of the CS6 apps so you might try that as well It fixed a cosmetic problem for me in Photoshop which was annoyig but not interferring with my work.
The update seemed to fix it.
So this might help get rid of the rectangle as well.
An update for CS6? Where?
Actually I did a updates through the help files and it said it had updates for allthe applications and it then installed the updates but apparently it was some form of shared component or the like.
As none of the apps are running with a point release version? So I do not know what that was about.
North America
Asia Pacific
