• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
BUG: Unable to Import MP3 Files in Flash CS6
Community Beginner ,
May 16, 2012 May 16, 2012
I am unable to import mp3 files of any kind in Flash CS6. Tried import to stage, import to library, Drag and Drop... no dice. Receiving a generic error message. Tried closing out and restarting,etc. - still not working.
Anyone else having this issue?
TOPICS
Import and export
Views
142.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Jun 13, 2012 Jun 13, 2012
For Flash CS6 on Win7, you need to update to QuickTime(7.7.1) and iTune(10.5.3.3) to import .mp3 files of which bitrate is larger than 192kbps..
Votes
Translate
Translate
Please follow this process before importing the MP3 files.
Launch the app, Press "CTRL +SHIFT+ALT" immediately
Menu will popup  "Delete Adobe profressional settings? "
Select Yes.
Then try to import the MP3 files.
Please let me know if its works.
Votes
Translate
Translate
Report
Report
May 17, 2012 May 17, 2012
Hi Josh,
Thanks for the reply.
The menu came up and I deleted settings, but still cant import .mp3's... are you able to replicate the same issue?
I'm on a 64 Bit Windows 7 box.
Here's a screenshot of the error:
Votes
Translate
Translate
Report
Report
Did you able to  play the same mp3 in windows media player ?. Check another mp3 can import in Flash. Please share the file if you are not able to solve this issue.
Votes
Translate
Translate
Report
Report
May 18, 2012 May 18, 2012
Yes, of course they playback in windows media player.  Use any Mp3 file... doesnt work for me... does it work for you?
Votes
Translate
Translate
Report
Report
May 20, 2012 May 20, 2012
I am not sure its an issue of  the codec used in MP3. Could you please share the MP3. I will try and reply back to you.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 12, 2012 Jun 12, 2012
I'm in the same boat. I cannot import mp3's. I did as mentioned above and still no luck.
This is true for ALL my files. The mp3's were also created with Soundbooth so there isn't any weird codecs either.
Windows 7 64 bit
Votes
Translate
Translate
Report
Report
Yep... its completely broken. Cant import any type of mp3 file into a .fla at all in Windows 7 64bit... pretty big bug.
I've been just saving everything out as wav's and importing as a work around.
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
New Here ,
Jun 14, 2012 Jun 14, 2012
Yep that worked!
The "update" in the library would not update the content but the drag and drop worked fine.
Note: The path in the update dialog shows a relative path and after the drag and drop it shows an absolute path to the file
I also had an issue with the audio being changed from stream to event.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 10, 2012 Oct 10, 2012
Do you need both QuickTime and iTune in order to import .mp3 files, or will the updated version of QuickTime be sufficient?
Votes
Translate
Translate
Report
Report
New Here ,
Mar 17, 2013 Mar 17, 2013
even im not able to import the music files to timeline and library.
when i try to import .MP3 file, its displaying an error "couldn't import the specified file.mp3"
when i try to add .wma files, its showing an error "one or more files were not imported because there is a problem while reading them".
any one can fix this issue?
Votes
Translate
Translate
Report
Report
Mar 29, 2016 Mar 29, 2016
What about for a Macbook Pro?
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 24, 2016 Apr 24, 2016
This is happening on my Mac and Windows10 (everything is up to date "EUD"). I tried using a generic Win&Mac mp3 converter, changed compression(s). I tried reseting my settings (that really sucked). Installed QT in Windows. Tried it on another mac.
.WAV files are working. Nothing online but older version of flash. I'm going to try opening an older file with an MP3.
Votes
Translate
Translate
Report
Report
LEGEND ,
Make sure the MP3 is 16 bit, and not 24 or 32. Also, being 44.1 KHz would help, but it's the fact that they are 32 bit that stops them from importing.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 04, 2012 Jun 04, 2012
I can't import them to the stage, nor drag and drop, anymore.  But they will import to library.  But I can't get them to preview.  Sound only when I publish.
Votes
Translate
Translate
Report
Report
Please share the file, I will find out a work around for the issue.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 20, 2013 Mar 20, 2013
Hi my friend...
1. Import the sound to library
2. Select the layer you want to import
3. Open properties dialog (ctrl + f3 or windows -> properties)
4. with a frame selected in layer - see the sound dialog box showing in properties
5. click the drag down and select the sound you have imported
it's ok now
6. you must select the sync as 'stream' for the sound to stop at the end of movie
thanks
Mahesh
Votes
Translate
Translate
Report
Report
Apr 09, 2013 Apr 09, 2013
I somehow managed to import my file, but still, did not work by Draging it in. Only after update of Quicktime and iTunes, I imported my 30mb file after comverting from .mp3 -> to .wav and it worked. Thanks.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 10, 2013 Apr 10, 2013
I couldn't import any WAV or MP3 files into Flash Professional CS6.
I had this issue when saving out of SoundBooth CS4.  There was a box in the Preferences>MetaData> "Include source XMP on save as"  this prevented Flash from opening the file... When I turned off the check box, MP3 and WAV files suddely worked.
Hope this helps someone else.
Votes
Translate
Translate
Report
Report
Contributor ,
Jul 15, 2013 Jul 15, 2013
I have the same Problem on my Mac OSX 10.7.5. I have the latest Quicktime Version and iTunes is also the newest Version. What do I have to do in order to import or even update mp3 files to my Flash CC project??
Votes
Translate
Translate
Report
Report
New Here ,
Jan 06, 2014 Jan 06, 2014
I had the same problem. But, i used adobe media encoder and reconvert it to mp3 then import it to library and every thing became fine
Votes
Translate
Translate
Report
Report
New Here ,
Apr 08, 2014 Apr 08, 2014
I just tried the encoder and it worked! I'm so happy!!!
Votes
Translate
Translate
Report
Report
New Here ,
May 12, 2014 May 12, 2014
Thank you. This worked for me.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 10, 2014 Jul 10, 2014
the encoder trick works for us too.
thanks,
Votes
Translate
Translate
Report
Report
