nik.savtchenko
► SWF File Elements Shift Upon Resizing Window
May 17, 2012 9:02 PM
I've created a Flash website. However, when I resize the published SWF (or the preview window within Flash) some of the elements get displaced. How can I create a "wrapper" like in Dreamweaver so that the window can be dragged out to any size and all of the components stay together as they were intended?
Here is what I mean:
http://i1124.photobucket.com/albums/l567/niksavtchenko/2.jpg
http://i1124.photobucket.com/albums/l567/niksavtchenko/1.jpg
Nik
  • kglad
    Jul 21, 2002
    May 19, 2012 7:43 AM   in reply to nik.savtchenko
    you can specify your layout in an onResize listener:
    var stageListener:Object={};
    stageListener.onResize=function(){
    // position header
    // position content
    // etc
    Stage.addListener(stageListener);
  • kglad
    Jul 21, 2002
    May 20, 2012 9:59 AM   in reply to nik.savtchenko
    your exact code depends on what you want.  but, for example, if you wanted your header to be centered horizontally and your content to be centered horizontally and vertically, you could use:
    // position header
    header._x = (Stage.width-header._width)/2;
    // position content
    content._x = (Stage.width-content._width)/2;
    content._y = (Stage.height-content._height)/2;
    // and you will probably want to check the stage scaleMode properties.
  • kglad
    Jul 21, 2002
    May 20, 2012 10:49 PM   in reply to nik.savtchenko
    what error message do you see?
    check the flash help files, the Stage class.
  • kglad
    Jul 21, 2002
    May 21, 2012 7:52 AM   in reply to nik.savtchenko
    are you publishing for as3 or as2?
  • kglad
    Jul 21, 2002
    May 21, 2012 11:27 AM   in reply to nik.savtchenko
    you're posting in the wrong forum.  the previously suggested code was for as2.
    for as3, your code will work.
  • kglad
    Jul 21, 2002
    May 21, 2012 5:38 PM   in reply to nik.savtchenko
    what do you expect to happen?  you only have a trace() statement in your listener function and it's not clear you know how to find trace output when you open that html file in your browser
  • kglad
    Jul 21, 2002
    May 21, 2012 10:34 PM   in reply to nik.savtchenko
