I have no idea how to
This book is made up of 300+ individual pages with individual text boxes, pages were scanned from a pre-existing book, converted using OCR to text, and inserted page by page, into individual text frames. This is a "reconstructed facismile," where each page must match as closely as possible (allowing for different type and letter spacing) the original.
I have no idea what ID tagged text is.
From what I had read throughout various threads and documents: exporting to IDML often resolves problems. Moving content from the "corrupt file" to a new file often resolves problems. Doing both, which is what 2 InDesign technicians had me do--"This will remove all problems"--so I did that to try to remove any "corruption."
Tagged text is a way to export text from InDesign and retain formatting information. Place your cursor in a story and go to File > Export... and Tagged Text will appear in the list. Try this with one or two stories to see what happens.
I'm not sure what you mean by moving content, since that's pretty vague and could mean anything from moving pages to copying and pasting frames or copying the content inside the frames and pasteing into new frames in a new file, which is what I asked you to try. The goal is to get the content, without the containers, into a new file for testing.
Since this is the first time you've provided any sort of detail regarding the document structure it's clear that doing the things I asked will be time consuming if done manually. I'm not a scripter, but I suspect that scripts can be written that will automate both tasks.
The other thing that needs to be investigated is your system configuration and what might have changed on May 5.
First, do you have any third-party plugins installed, or a font manager? Second what changes were made to your system around the time that you started having problems? Have you tried using System Restore to go back to an earlier time, say May 1?
You've mentioned talking to "Adobe Technicians" a couple of times now. Do you have a support contract, or are you talking with the outsourced support people in India? If the latter, unless you've managed to get yourself escalated quite a way up the food chain you aren't really talking to an Adobe "technician," but rather someone looking in the knowledgebase and reading from there or from some other script. The odds that this person is an actual user of InDesign, let alone a skilled user or troubleshooter, is pretty slim.
Here on the forum we are all volunteers, some of us with years of practical real world experience with both Adobe products and the hardware and software that the applications run on. I've been a production user of InDesign since version 2.0 was released and I dabble in building and troubleshooting PCs and the Windows OS (though I don't claim to be an expert in the inner workings of Windows). John, who was here earlier, has extensive experience troubleshooting InDesign and is a Linux and Mac OS developer in his spare time, I think. He knows more about the inner workings of ID, I suspect, than anyone not actually on the Adobe payroll. He is probably also our top expeert on Mac system issues, which unfortunately may not be helpful for your Windows system.
The point I am trying to make here is that talking to tech support may not get you good answers, but if you answer our questions here, and follow the directions we give, we actually have an extremely high rate for actual problem solving, many times after a user such as you has tried the Tech Support line without success.
I uninstalled Sigil and reinstalled it around then. Nothing else. The only Windows updates I am aware of were this week, otherwise nothing even near May 5.
I don't have a font manager. I have no third-party plugins for InDesign--nothing I've downloaded or installed.
The last system restore I tried (following a Windows update in March) failed.
"Moving content" was what several Adobe technicians said in the context of using the Move Pages in the Page Palette drop down menu . . . which moved pages/content into a new document. Likewise, they too used the word "corruption."
The Adobe technicians have left a very bad taste in my mouth. Since May 7, they have hung up, not called back as promised, and fundamentally done little except to promise to call in 24-48 hours.
My case was escalated. I use the phrase "technical support" because that is what Adobe calls them. Yes, I know for a fact that several could never have used InDesign in their lives.
I am very active in the CreateSpace forum (print-on-demand books). It too is volunteer. I probably spend no less than 3 hours a day helping people. And, Customer Support at CS is friendly, South Carolina residents, who know mean well, answer easy questions, and are otherwise clueless. I spend hundreds of hours trying to figure out the nuts and bolts of CS printing because they say nothing about anything technical, including what presses they use. I am probably your equivalent on that forum.
I will use the word corruption because from my point of view it fits. You are suggesting, and it makes sense, that something (a container, frame, etc.) is holding corrupted or corrupting data that is causing this problem. (In Word, for example, the ¶ and section breaks hold formatting information; when the formatting gets corrupted, that corruption is generally held in one of those. Find the right one and it usually removes the problems. And regarding Word, the word used is "corruption.") That it happened to two unrelated files (we all suffer from the post hoc ergo proper hoc syndrome) may be coincidence.
I will try to extract the text, assemble it outside InDesign, then put it back into a new, clean file.
It will only take 15-20 minutes, usually, to find out if System Restore is successful. Odds are good that you've made enough changes that it won't be, but if I were having your issues at this point I'd try it.
Beyond that, you really should try the tagged text and copy paste steps I outlined earlier. If there really is something corrupt about the file it may be tied to the frames themselves and this is another possibility for clearing it. Just do some random samples to see what sort of performance you get.
Might also be worth disconnecting from any network, to isolate the machine for safety, then run MSconfig and turn off all your security software and any other unnecessary startups, then start up again in Diagnostic Mode (just restart from MSconfig) and see if that makes any difference.
Do you have a default printer? Is it local or network, and is it turned on? Does it make a difference if you change to the Adobe PDF printer, if available, or Windows Fax or Microsoft XPS Document Writer as the default?
I think we've been presuming so far that your files are stored locally. Is that really true? Or are you working across a network or on a removeable drive?
OK, so you're pretty good with computers. That helps. I wish I could say I thought that "Tech Support" was ever helpful, but honestly even escalated I'm not sure you ever get to someone who knows what they are doing. I'd be encouraged if someone you talked to asked you to send the file in for examination, but it doesn't sound like that has happened, so I doubt you've reached any one at Quality Assurance yet.
That's it, exactly. Most file "corruption" in ID is either so serious that file is unopenable, or it responds to cleaning via export. That John and I both started by saying we didn't see evidence of corruption simple means your problem is very atypical. The export method is really a side-effect benefit, not an intended consequence of exporting to interchange. In my experience, .inx (the older format) was more reliable as a cleaner than .idml, and given a choice, that's the one I pick. Do you think you've used any features in the file that would be lost by exporting all the way back to CS3 and .inx? Do you have CS4 availble? If not, I'd be willing to try that for you and see what happens.
I was asked to upload a file for test. That represents two of the "we'll call you back" promises never kept. The other file that "corrupted first" came from a Word file I flowed into an InDesign file. So the process of adding text was completely different between the two; but both have the exact same problems.
I will try what you suggest . . . and I'll let you know.
If you're ever wandering around CreateSpace, look me up, user name Walton.
walton
Not cool. Did you get a name or a case number?
I have some limited contacts at Adobe, so I'll send some emails and see if I can get someone to follow through with you.
When my case was escalated they gave it a new number 183 225 755. The original technician who escalated the case was Manav (whose full name, I think, was Akiklesh Dhorta). The technician I spoke with last night, Chanchal, promised yet another a call back, after the first call back never happened in its 24-48 hours, thus another 24-48 hours--that would be today or tomorrow. I asked if they were really going to call me on Saturday or Sunday, she said, "ok, we will call you back in 2-6 hours."
I explained that would be 8:30 pm to 12:30 am. But, I would gladly take the call if they called me back.
She said, "If since it is okay, then we will absolutely call you back in 2-6 hours." She promised this several times.
Take a guess if they called back?
Between the Photoshop 3 and Photoshop 6 or 7 days, service and support from Adobe was fantastic. Without question since CS 2 it has been a tad less than stellar.
Update:
The first 170 pages seem to work fine, somewhere between170 and 230 the "corruption" starts and gets worse and worse. Removing the text and text boxes from 170 - 230 seemed to help a little, but re-inserting the text (from NotePad) into new boxes set things back to square one.
Threading the text boxes, which would enable me to remove all the text and start over, takes 1-20 minutes per text box: not such a great strategy.
That leaves copying text page by page into say NotePad. Not too bad on the pages that work, but that can take up to 7 minutes per page in the bad pages, and it introduces huge errors because the text does not always copy and paste correctly. (In case anyone thinks it's the mouse, I'm currently using a Wacom tablet and mouse, both of which work with the utmost delicacy in Photoshop.)
It is not that I don't expect problems, I do. It is not that the first person doesn't have an answer, I solve problems on the CreateSpace forum every day, and I know that it is not always easy. What I do not expect and what is totally unacceptable is that this has been going on since May 5, first reported May 7 and has met with utter incompetence.
Thanks to everyone here who has tried to help.
I don't know if this free script from Rorohiko.com works in CS5.5, but if it does it can automate threading for you: http://www.rorohiko.com/wordpress/indesign-downloads/textstitch/
I just spoke with the senior support technician, who is handling the escalated case, and who is examining the file.
"It is a corrupt master page. It may be as many as four corrupt master pages."
He does not know why the master pages are corrupt. "Corrupt" is, by the way his word. He is having his team look further into this, and if they cannot figure out why the master pages are corrupt, he will send the document to engineering.
He said that if he breaks the document up into smaller documents, which can later be combined in the Book palette, he has no trouble moving the text boxes around. Also, if he deletes the master pages, everything works fine.
So manipulating the text itself, as has been suggested, would not, in this case, do anything. Reinstalling InDesign was also not helpful--except that it would rule out a "corrupted" installation.
Actually, that statement is probably not true. Moving the text, without moving the pages, would leave behind the old master pages.
". . . would leave behind the old master pages": true, as would re-applying the OCR process to 512 scans and creating a new document--unless the new master pages (this has happened in 3 new, unrelated files, now) become corrupt. And if the master pages were loaded into the new document, that could also re-introduce the corruption. The senior support technician seemed to think that dealing with the text was not the answer.
The answer I would like to avoid is: when this happens, write a new book. I thought, by updating this, and I will again if I learn something new, would be helpful to the community.
I do appreciate your help and time.
Who suggested writing a new book?
Obviously there is something corrupting the master pages, and that's not something I can identify. If that something is in some way related to the OCR process re-doing the OCR would not be a good way to try to solve the problem. It's far less likely that the problem is something fundamental to text handling (though not impossible) so importing tagged text, or copying and pasting text, into a fresh document is likely to work UNLESS there is actually some problem in the text itself that is being transferred. Since tagged text is basically ASCII, there's not a lot that can get moved that way. Copy and paste of formatted text could bring problems, pasting without formatting would be less likely to do that.
If a new file then becomes damaged when working with clean text, that looks a lot like a localized configuration problem (this is the sort of bug, if truly a bug, that would have been caught in testing if it happened in the general case). That could be either some third party plugin or other program causing a conflict, or it could, in fact, be a bug that is triggered only under the very specific circumstances present in your work. Those do happen. Either scenario can be very difficult to troubleshoot.
I hope the team gets back to you. I expect they may ask you to run some diagnostic tools and collect a few logs to help track this down.
Thank you, I will report back. As I said, however, this problem has occurred in three separate files. One, the one being worked on and the subject of this post, was made up of unformatted text, which saves a txt. Two others were made by flowing a Word file in. The only commonality between these files is InDesign.
I spent some time bringing text by way of NotePad into a file and it became corrupted . . . due, presumably to a corrupt master page. I have no plug-ins that aren't integral to InDesign itself, I have not installed any plug-ins otherwise.
The problem is that, aside from missing several deadlines, I do book design and formatting for a living, and not being able to trust that the next InDesign file will work properly, as it has over the years, basically puts me out of business--if 40hour jobs take 160 hours (and here, with no end in sight), bagging groceries looks good.
I haven't had a chance to read this thread in detail, but are your multiple corrupt documents sharing something in common? Did they originate from a common template? Were master pages copied from one to another. Was one file used as the basis for another?
Have you been able to reduce the corruption down to a minimal document?
I'll try to review this later today and see if I have any more useful insight beyond being grumpy about the version numbers (sorry about that).
The multiple corrupt documents share nothing in common, except:
Removing the master pages resolved the problem on the file about which I have posted. It appears that 2 of the master pages were corrupted. However, 2 more could not be used as a bases for new master pages, leading me to think that to some degree four master pages were corrupt.
What Adobe has not done, despite promises and promises and promises, is call back, so I have no idea how to prevent this from happening again, unless it was simply a fluke that three files got corrupted. To get the answer today, required six phone calls today alone, from 5:35 to 7:39. I was only hung up on once!
This morning, I asked one of the technicians, "With regard to technical issues and service, what options do I have?" (Thinking I'd pay for help, that's cheaper than not working at all for days and days.)
Answer: "You have no service options with Adobe, except techincal support." That is: them.
OK, so, I finally got a chance to read this through this thread. Can you post a link to one of the problem documents, or email one to me?
(Sorry, I had thought you had done so earlier, but I realized I just misinterpretted something you said).
Another thing to try, of course, is testing against CS6 (8.0.0.370). CS6 does fix a number of bugs and it's where engineers do development, so it's most likely to get easily fixed in CS6 before CS5.5, and there's a not-insignificant chance that CS6 fixes your problem already.
I think your best bet at this point is to try to isolate the problem and determine what about your documents causes this problem. While getting a new version of InDesign out that fixes your problem is not going to happen quickly (if at all), figuring out how to avoid the problem certainly is doable. After all thousands of people use ID every day and don't see this.
The best start is to get a minimal document that exhibits the problems (as few pages as possible). Once there, exporting it to IDML and opening the IDML in ID to confirm the corruption survives the IDML. If that's the case, then you can unzip the IDML and inspect it (it is human-readable XML) and try to determine what is unique/special about your document.
This might be a long odyssey. Of course, my experience is that putting in the effort is more likely to get you results than letting Adobe Support do it for you, but you might have a different scenario.
I don't want to make excuses for them, but I suspect what's going on is that the support people you are talking to are waiting for the higher-level support people, or even for Engineering, and they don't have good control over the timliness of those other people. But that's not an excuse for giving you callback estimates that are not met -- Adobe seems to have a serious problem with this and I would not give them a free pass for it. It seems to happen all too often.
If you totally get stuck you could try asking for the Noida Duty Manager and see what that gets you (Noida, UP, India is the location of Adobe's support center).
But realistically, I'm not sure that is going to make engineering work any faster. Maybe it'll just make them give you more realistic estimates for calls-back...
I will try to put together a small document that demonstrates the problem, possibly tomorrow.
Over the weekend, after uninstalling InDesign, running CS 5 Cleaner and reinstalling it, the file I looked at and reported on had been exported to IDML, openned, then I moved the pages into a new file. That file was again exported as an IDML. Opened, pages moved to a new file. The resulting file had the same problems.
Unfortunately, I have lost two weeks of gainful employment over this, and have 3 deadlines that I have missed . . . and don't have much time left for experiments.
Moving pages is probably counter-productive. I don't know what the names of your pages are, but if you move a page to a new doument that does not have a master with exactly the same name already, ID will move your master page, too, and if that's corrupt you've gained nothing. Likewise, continued export to .idml is probably futile as you've already demonstrated that whatever the problem is survives the process.
Update:
The "developer group" is looking at my file, and the senior support technician, who found the problem with the corrupt master pages, will be reporting back to me tomorrow.
However, he said the reason my files were bad (he did not use the word "corrupt" this time, in fact, he danced around it) was that I used "multiple master pages."
"So, you're telling me that the cause of the corruption is that I used multiple master pages?"
"Yes, that is correct."
"But isn't InDesign intended to use multiple master pages, and aren't they set up so that they can be linked together?"
"Yes, but you used multiple master pages [12 total], that is why you have problem. You have them linked to Master A, you must have them linked to None, then it will work."
Ah, I've sent a copy of this to George Orwell, I think he'll know the answer. Meanwhile, I'll post the developer group's answer, which he absolutely promised to have tomorrow, "These are the engineers who created InDesign."
Sounds like total nonsense to me. Of course you should be able to base one master on another. That's 100% standard and supported.
I think you have to read this a bit more carefully, realizing that it's probably not written by a native English speaker, and realize that it's not Orwellian.
You are dealing with a bug.
Of course InDesign isn't supposed to have bugs, but everything has bugs.
There is some reason why the bug is being triggered in this case. This guy is trying to tell you that the problem is related to chained master pages (I think. Though that detail isn't critical to my point), which is not something that everyone does, and if your master pages were arranged differnetly, you wouldn't have the problem.
This is undoubtedly true. He's advising you of the area in which the bug lies. This is useful information, because it gives you a clue as to how to avoid the problem.
It's not meant to be a "solution," but it's informatino about the problem so you can workaround it. And indeed, so Engineering can fix it.
I am curious, do you have 12 independent masters, or do you have masters that are based on other masters, or deeper hierarchy levels?
Oh right, I have your sample file. Yeah, you have A on which you base B on which you base C on which you base D ... all the way to M (13).
That's definitely not a common configuration, and one I suspect you could avoid by flattening your master hierarchy a bit. It's a lot more common to have, say, 8 master based on 4 different masters.
We spoke very carefully. I believe what he was trying to do was deflect the basic problem from InDesign to me. But the problem has been escalated up beyond him, so that is good.
But he was correct: there were two badly corrupted master pages and two that were only a little bad. Thus removing them and rebuilding them was the correct work around: however, it does not prevent it from happening again, and since it did happen in three unrelated files (the only three files I've created in InDesign with headers in the last month) I have no reason to assume it won't keep happening. He also said my file was big. The first file to corrupt this was had 12,000 words in it and 8 chapters, and it was created from a Word file.
In formatting a book with 16 chapters, where each chapter has it's own headers (e.g. title/author, or title/chapter name), this is easily accomodated with linked master pages. If the author changes the tile of his book from "Around the World in 97 Days" to "Around the World in 80 Days" it's a piece of cake to change that, once, and it flows through the entire book. The text in the running heads is the only difference between the master pages.
Creating separate master pages, where everything has to be created from scratch, could take me several hours (sixteen masters total), and wouldn't be as goods as linking them.
This may not be common, but certainly if Word can handle a 80+ different headers, gosh, I would assume better of InDesign.
I'll keep you posted . . . and thank you for the help!
I'm afraid I don't understand.
It's quite common to have, say, 11 master pages all based off a single master page. That is, Page A has common elements, and then pages B through M are based off of page A. It would seem like that would fit your requirements handily. Two levels of hierarchy.
It's also reasonably common to have a bit more hierarchy. B, C, and D are based off of A, and are 3 different variants. Then E though M are based off of B, C, and D, depending. And then perhaps there is a special variant of M that changes on item. So three levels of hierarchy, plus the odd 4th.
But what is uncommon is to have a twelve levels of hierarchy. Certainly it should work, but it's out of the ordinary, and bugs often arise in out of the ordinary situations.
InDesign can easily handle many many master pages. But what's special in your case is the hierarchy depth. So comparing it to 80+ headers in Word is not the right comparison.
Link them all to a single master and spend a few minutes cutting and pasting pages. I don't see why it would take several hours at all.
It may also be possible that the entire book can be done with a single master, if all that is changing on your current masters is the headers/footers. This is waht variables exel at doing, and a running header variable or two on a single master may be able to do the work of all twelve that you are using now.
Please, anyone reading this, let me know if you've had this problem. CS says you have if you use more than 3-4 linked master pages.
The answer from the InDesign Development Team is:
This means that global changes cannot be made, other than chapter-by-chapter. The result for most books I format, would be an additional 10+ hours--unless, of course, I chose to ignore problems and only format.
My questions were, and has not been answered: If this is normal behavior for InDesign: 1) Why didn't people on the InDesign forum get it quickly? 2) If this is normal behavior, how could I for years create books with 30-100+ linked master pages without these problems? 3) Why aren't these limitations on Master Pages discussed somewhere--certainly not that I have found.
A master is like a background that you can quickly apply to many pages. . . . You can create a master variation that is based on and updates with another master (called the parent master) within the same document. The master spreads based on the parent master are called child masters. For example, if your document has ten chapters that use master spreads that vary only slightly, base all of them on a master spread that contains the layout and objects common to all ten. This way, a change to the basic design requires editing just the parent master instead of editing all ten separately. Vary the formatting on your child masters. You can override parent master items on a child master to create variations on a master, just as you can override master items on document pages. This is a powerful way to keep a consistent yet varied design up to date. [Using Adobe InDesign CS5 & CS5.5, pg 70 & 72, November 16, 2011 update, from indesign_cs5_help.pdf]
Got it! When Adobe itself says "ten," it really means "three to four." Wow, don't I feel stupid now. My apologies to Adobe, for ever doubting them! Most embarrassing of all. . . they said "three to four" ten times!
For the record, Amir, who I mentioned above, is I beleive 100% sincere and concerned. He has been, unfortunately the messenger in this.
Peter, I will look at variables. Thank you.
Well, let's see.
Did you get a bug number?
• No InDesign file can have more than 3-4 linked Master Pages without them becoming corrupted
I think we need to be a bit more clear what "linked Master Pages" means, because for the naive interpretation that's certainly not true.
I think they are perhaps saying, "If you chain more than 3 master pages, you are likely to experience corruption." And by chain, I mean master page D depends on master page C depends on master page B depends on master page A.
That level of hiearchy is not normal for most InDesign users, so I am not surprised that there are bugs there that have not been found.
It's emphatically normal for documents to have many (e.g. scores) of master pages that are all linked to a common master. That is, B1 through B20 all depend on A.
In any event, any corruption problem is unambiguously a bug. Make sure to get a bug number. If there is resistance, that is bad, and you should push harder and escalate.
• This is true for al versions of InDesign
• This is normal for InDesign
Well, if the claim is that this is not a new bug and it has always existed, I do not find that claim surprising. (For the aforementioned reasons.)
• The only way to avoid the problem is to create smaller documents, chapter by chapter, and use the Book feature to combine them in to one finshed file for printing
This I don't get at all. Why can't you just use Master Pages in the normal way? (I've been trying to ask that for several posts, but perhaps
I have not been clear?)
OK, I don't have any files I can find with more than two or three masters based on the same parent, nor any with a chain of masters such as you initially described where a is based on b is based on c is based on d is based on e... so that page z would have 25 generations of parenting to go back through. Note that this is NOT the scenario described in the help quote above. That desribes b based on a, c based on a, d based on a, and so forth, and that's a quite common setup.
It wouldn't surprise me to see a long document with more layers of dependency, but I've never needed to go more than three, nor do I recall a case where I needed more than about a half-dozen masters in any single document, certainly not since the introduction of variables, but I tend to build really long docs as Books, not single files, just to make it easier to navigate and to spread the risk of total destruction. That said, I find the not-more-than-three-or-four-masters explanation completely without credibility. For one thing, I can't imagine you are the only one to ever try it, and if you are not, I can't imagine that in ten years nobody else has posted this "design limitation."
I sent you a link to small file that isolated the actual problem. It may or may not have had more than 1 master page, I don't remember. I didn't realize you wanted more.
I have been reading about variables, so far I can't figure out how the would work. Just call me stupid. Actually . . . I generally use (this is the pattern I used in the three files that corrupted):
A,
B base on A,
C base on B,
D base on C,
E base on D,
Ultimately, this has been my understanding for many years, if I change A, that change flows through to the E, etc. Maybe I didn't say it artfully enough earlier.
But what I read in the Adobe's InDesign Manual is that I am doing what InDesign is supposed to do. Variables, at least so far, won't, but I'll get there if it's possible.
There is no question that you should be able to do what you are describing. If you are getting document corruption due to using this type of document organization, you are indeed encountering a bug. And even if is either a built-in or defacto limit to such chaining of master pages in InDesign, the program should prevent you from having any more than such a limit and certainly not let your document.
I've looked through our internal bug database and could not find any open bug that seems to correspond with anything like this. Do you have any information from whoever spoke to you in Tech Support, either a bug number or a case number for your incident?
- Dov
North America
Asia Pacific
