What happened to the plug-ins in CS6? Can you move them from CS5 to CS6?
May 19, 2012 9:05 AM
Have they been renamed and placed in another folder/area? Or am I asking the obvious?
    May 21, 2012 11:15 AM   in reply to Katharine Gilbert
    You SHOULD NOT move plug-ins from any Photoshop install to another Photoshop install unless you know what you are doing!
    You should run the plug-in installer so it can do the right thing. If your plug-in installer cannot "see" Photoshop CS6 then contact the developer of the plug-in so they can create a new installer for you.
    If your plug-in is using Extension Manager make sure you run the correct version of Extension Manager for the suite app you are trying to install into. Extension Manager CS6 for Photoshop CS6 for example. You can right click or control click on the extension and pick the Extension Manager to launch.
    WARNING: Most of the time, users who try to manually copy, end up with not only a plug-in that will not work but a broken Photoshop that will not launch! You are better off working with the plug-in manufacturer.
    May 21, 2012 5:12 PM   in reply to Tom Ruark
