Bridge does NOT started at boot.
Windows 7 -64 (all current updates).
Photoshop CS6 13.0 extended
Bridge 5.0.0 399x64
After closing Bridge by clicking on the Close X or file/exit, the process 'bridge.exe' does not terminate and therefore thereafter trying to restart bridge fails.
Have to open up Task Manager, kill the bridge.exe process, in order to restart bridge.
The bug is so variable that just when it appears repeatable, something changes.
Any idea of what to look for?
When this happens I assume it is running in the background becasue it shows in the Task Manager?
Have not seen this problem on my machine. Are you sure it is cs6 that is running and not cs5? Only one version of Bridge can be run at same time.
I assume you do not have "start bridge at login" checked in advanced preferences?
thanks for your reply but to review my original posting:
Bridge is NOT started at boot.
Windows 7 -x64 (all current updates).
Photoshop CS6 13.0 extended (x64)
Bridge 5.0.0 399x64
This bug does not involve any previous versions of PS or Bridge -- just a new install of PS CS6 extended x64.
and just to restate for those who might have the problem with different versions of Photoshop installed on the same system -- we are observing that the process name for Bridge CS5.1 will appear as Bridge.exe*32 not the CS6-version of Bridge.exe.
Another tip for those who might have both PS CS5.1 and PS CS6: pay attention to which version of Bridge is executed when in PS CS5.1 and selecting "browse in Bridge". On other -x64 systems, we observed PS CS5.1 executing Bridge CS6. Additionally, in Bridge CS5, check Edit/Preferences/File Type Associations are correct for the intended version -- pay attention to the executable directory for x64 vs x32. We are observing that all filetype associations in Bridge CS5 are being overwritten to PS CS6 after installation.
I'm not sure this is the correct way to quit Bridge (I'm a Mac user so please help me out here)
To me this sounds as closing the open window instead of quitting the application. Now it is possible this is the usual way to quit applications in Windows but Fro Bridge I doubt this is a correct way. On a Mac I have to choose either the shortcut cmd. + Q or go to the menu Adobe Bridge CSxx and choose 'Quit Adobe CSxx)
Also you can have only one Bridge version active at the time. If you have the need to switch back from PS CS6 to earlier versions of PS on your system (Multiple versions of PS can be active at same time) you might want to change your workflow a bit and only use Bridge CS6.
Don't use the Browse in Bridge option but act from within Bridge itself. Richt click on a file or a multiple selection of files gives you the option to choose from 'Open With" and inhere should be a list from all version of PS on your system.
thanks for your reply:
FYI: In Windows, to exit a program/application, clicking the Close button
in the upper-right corner of the program window is the same as using the File menu, and click Exit.
Again, since there is ONLY CS6 installed on this box, duplicate versions of Bridge cannot be the issue of the non-terminating bridge.exe process.
There doesn't appear any consistency to this non-terminating-bug so whether the Bridge application is initiated in Photoshop or from Windows explorer platform, it appears something else is stopping the 'stop' execution. Furthermore, certainly it would be considered a major BUG if executing the BRIDGE from WITHIN Photoshop would cause an application failure :>)
Because of the inconsistency of the failure to end Bridge.exe, we suspect there's some type app conflict.
So we've finally been able to replicate this CS6 Photoshop/Bridge/CameraRaw 7 bug:
1) start Photoshop
2) browse to Bridge
3)double-click image (so back to PS)
4) browse to Bridge
5) single-click image
6) open Camera Raw
7) make adjustment
8) OPEN OBJECT
9) in PS: file/save as
10) browse in Bridge
11) close Bridge (bridge.exe does not terminate)
12)back to Photoshop
13) close Photoshop
Bridge.exe does not terminate
This is NOT TRUE. "FYI: In Windows, to exit a program/application, clicking the Close button
in the upper-right corner of the program window is the same as using the File menu, and click Exit."
If you click the red X you close the window and force close of the program. Any changes you made to program will not be saved if you have the option "start Bridge at login" checked. If you click File>Exit the program will go through the procedure to normally close down, and any changes you made will be saved.
I tried to follow your steps but was confused on steps 3,4,5,8,10.
I used 1,2,3,7,9,11. Bridge was closed. Perhaps with all your "browse to bridge you are opening multiple copies?
Hey, how about trying and commenting on my problem with the Find function in CS6? http://forums.adobe.com/thread/1007726?tstart=0
Whether you close a program with or without saving an bit-marked file should ALWAYS result in terminating the parent process if not user dialog is launched -- this is just standard coding procedure and therefore considered a BUG if there's no initiation of close-program routine.
check how you have configured Bridge to open Camera Raw -- we're set to AUTOMATICALLY OPEN JPG with SETTINGS and tiffs off
Not a programmer, just recording how the program responds. Some like to have all the settings remain the same no matter where they close the program.
Mine are on.
But that is imaterial to what I did. Opened raw image (NEF) by double clicking. THerefore 3,4,5,6 not necessary.
When you use Find and choose "include non-indexed files" can you see indexing working?
I see the same error on a windows 7 ultimate 64bit but then on the process photoshop.exe,
Only CS6 is installed. Starting the process by clicking on a picture choose open with photoshop.
After closing doesn't matter for how long working in it. It still keeps running after closing photoshop.
So open and direct closing gives the same problem. I have this since i reinstalled my PC and installed CS6 directly without first installing CS5.5.
Before that i had no problem with it.
I believe the problem of Bridge not closing properly is related to the caching function within bridge, and two separate problems that I have already reported as bugs.
In short, Bridge CS6 is constantly re-caching whatever folder it is pointed at. Prior versions did not do that. For most file formats, Bridge CS6 is scanning the files, looking to see if they are in the cache, and doing nothing if true. But then it does it again, and again, and again.
In the case of layered tif files, it will actually re-write the thumbnail jpegs in the cache. You can see this in the progress bar, and it can take a lot of time and CPU if the folder has a lot of layered tifs. Curious that it does not re-cache the thumbnails for layerd PSD files, only tif. I'm not sure what it does for mp4, wmv, PDF, etc.
If you close Bridge CS6 while it's caching, the window will disappear, but the task remains, and keeps using CPU.
Combine this with another "bug" where Bridge has a "deadly embrace" with Photoshop. If you save a file in Photoshop, Bridge takes off trying to re-cache the file. If you quickly do another save from Photoshop, you may get the "can not save, file in use by another program" error. The other program is Bridge.
I can generate this error condition easily by running the image processor from Bridge on a batch of tifs, outputing jpegs to the same directory. The image processor gets 2 or 3 files done, then stops with the "file in use" error. If you let the image processor write the jpegs to a separate directory, no problem. In that case, nothing is triggering Bridge to re-cache, so conflict arises.
For the OP and others who have the problem of Bridge not closing, try this: Before attempting to close Bridge, point it at an empty directory (so there is nothing to cache). Then try to close. That works every time for me.
Adobe has sent me an e-mail acknowledging the constant re-caching of layered tif files, and promising attention in the next update, which I'm eagerly awaiting.
Woops - forgot. The constant re-caching of layered tifs can be stopped by disabling tif support in Camera Raw preferences. But there is no way to disable PDF, MP4, WMV, support. I don't keep any of those folders I use for Bridge, but I would not be surprised if some of them cause the constant re-caching.
Even without the re-caching of layered tif thumbnails, Bridge appears to re-scan the active folder whenever anything changes in that folder. Even if the change is made by another program (Photoshop). If you try to close Bridge while it's doing the scan, it may get hung up and not fully terminate.
I have the same problem after installing NIK software CEP 4.0 - Photoshop CS 6 does not shut down. (have installed and uninstalled CS 6 and the plug in a lot of times) Have been in contact with NIK, and they have been very kind and tryed to help, but the problem is still there, but not wih my 8 other plug ins.
No problems with my former CS3 intended
I have this problem as well. I too also had CS3 before installing CS6. I have Windows 7 Professional 64-bit though.
My bridge (64-bit and 32-bit) closes down properly (the process closes), but for programs like Photoshop and Premiere, the window closes down (like normal), but the process still remains in Task Manager.
This is very annoying as I have to close that process before I can re-open Photoshop.
I have tried the 64-bit version and the 32-bit version of Photoshop as well as doing File -> Exit, but the problem still occurs.
I thought it was the update I did that caused this, or that there is a conflict between the remnants of CS3 and CS6, so I uninstalled CS6 and used Adobe Creative Suite Cleaner Tool to clean CS3 and CS6.
After I re-installed CS6, the problem still occured.
No idea why the process doesn't end.
Interesting:
So there you are - as a sad clown in circus.![]()
But it is interesting, that the problem also is there without this plug in.
I had similar problem and the solution to fix it could be here: http://www.youtube.com/watch?v=VMlsmY7VvvY
Tested on Bridge CS6, Windows 7 64bit
North America
Asia Pacific
