My trial CS6 installation failed, exit code 15
May 20, 2012 3:03 PM
Tags: #cs6 #adobe_download_assistant
I have tried several times now, shutting the computer down several times, nothing seems to work... any ideas? It installs up to 2 % and then quits
    May 21, 2012 3:11 AM   in reply to anke55mom
    Run CS Cleaner Tool and then remove all CS6 products, and then try again.
    Location and instructions to run the Cleaner Tool in the following document: http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation -problems.html
    May 21, 2012 6:01 AM   in reply to anke55mom
    Any other older version? CS5 perhaps? Or maybe Photoshop CS6 Beta?
    What program are you trying to install?
    Run the CS Cleaner tool anyway, and then retry.
    May 28, 2012 12:30 PM   in reply to anke55mom
    I hope some of you did figure out a solution. I was trying to implement the suggestions by the kb provided by Adobe:
    http://helpx.adobe.com/creative-suite/kb/exit-code-15-installing-ccm.h tml
    I failded.
    Then I was in touch with an Adobe Expert and they provided me the following how to:
    1. Enable the root user account and then try to install the software, the steps are provided below.
    1a Choose Apple menu > System Preferences, and then click Users & Groups.
    1b Click the lock icon to unlock it, and then type an administrator name and password.
    1c In the Network Account Server section, click Join or Edit.
    1d Click Open Directory Utility.
    1e Click the lock icon to unlock it, and then enter your administrator name and password.
    1f Choose Edit > Enable Root User, and then enter a root user password in the Password and Verify fields. Be sure to specify a secure password.
    2 Create a new admin account and start your Mac in safe mode log in to the new account and then try to install the steps.
    These two steps will help you to install the software in your Mac.
    Hope that helps you too.
    Cheers,
    Vome
    May 28, 2012 3:06 PM   in reply to anke55mom
    @anke: The link below would help to enable Root user account.
    http://support.apple.com/kb/HT1528
    Jul 11, 2012 4:17 PM   in reply to anke55mom
    Spent the whole day on this. (I only got this message after my first attmepted install had frozen). Tried the solutions at http://helpx.adobe.com/creative-suite/kb/exit-code-15-installing-ccm.h tml to avail.
    I'm using a Macbook Pro with osx 10.7.4, I manually searcher /Libary for adobe files to delete that the cleaner tool misses. My install worked after deleting /Library/Application Support/Adobe, then installing in safe mode. HTH.
