I'm not that techy, either, Marc. Cocktail is a 3rd party utility that does much of the same stuff that Onyx and others do. It handles a number of "housekeeping" chores. To digress, I periodically run Disk Warrior (rebuilds disk directory) followed by Cocktail, usually before updating system software, and that seems to keep things running smoothly. (Little errors and problems gradually crop over time, especially if you create lots of files and are a robust filer, unlike most consumers who leave it to the system.) Anyway, Cocktail has a Pilot mode that by default runs what most of us will ever need done. It's simpler than the more involved ways to get to the same end. (I have no connection with Cocktail other than being a satisfied user.) You'll find it easily in a search. Don't remember if there's a free version, or how much the paid version costs, but it isn't much. The Pilot function is easy to find, and you just click run.
You do not need to mess with the DS STORE files or any other settings. Just go to Pilot and click run. (I should add that I did run Disk Warrior before Cocktail when I solved the problem. I doubt that rebuilding the hard drive directory was the solution--the problems fixed were too few and more-or-less routine. What Cocktail does is more relevant to what the earlier posts were saying.)
A true techy can answer this better than I can. All Disk Warrior does is repair any errors in the hard drive directory, essentially the filing system for the computer, so it knows what files are stored where (among other things). It's like Apple's Disk Utility app, but historically has been more thorough. Directory errors can lead to various odd behavior by the system or apps at different times. You may or may not have directory errors, or at least any that matter much, and most users never repair or rebuild their directory (and most will use Disk Utility if they do), but that's a separate topic from this one. Just run Cocktail on Pilot and see if the icon problem is fixed. I recommend restarting the system immediately after running Cocktail. (I only mentioned Disk Warrior because I ran both it and Cocktail as part of my standard troubleshooting routine. Better would have been to see if anyone said Cocktail didn't fix the problem before mentioning Disk Warrior.)
Hi Chris and folks of this discussion.
I deleted DS_store files as suggested ealier in this discussion and that did not solve my missing icon problems. I wish that Adobe and Apple had a more active relationship so that this issue could be resolved as it's a very important issue to be solved.
I belive Chris Cox of Adobe when he stated Adobe can't replicate this problem but I'm baffled why they can't. I also offered to email data to help.
It was also suggested that we post this problem on Apple's online forum. If anyone has a specific place for me to post, please let me know. Thank you.
I did exactly as Rick said and ran the PILOT on my newly installed Cocktail and following that shut down my computer. All of the thumbs returned on the images saved in PS6. So that did it without Disk Warrior. I still may investigate DW as well though. Thank you Rick. Hopefully they will find a fix for this. It really through me into a loop.
I too have this issue and ran Onyx as well as Cocktail PILOT, but I don't think it helped
Previews are still missing in Column View for both finder windows and in the Photoshop Open dialog box. If I switch to coverflow view, I see the previews just fine.
Sad thing is that I live in column view in the finder and in the Open and Save dialogs of Photoshop. Traversing directories with Coverflow is awful.
Is anyone else experiencing this problem only in Column View?
I have not upgraded to Mountain Lion yet--I usually wait for the first update to a new cat before installing it--but the icon problem has not returned since running Cocktail on Pilot per my earlier post. That specifically includes column view, which I use nearly 100% of the time. If Cocktail didn't do it for you, I suggest rebuilding your disk directory using Disk Utility (or Disk Warrior, if you have it), then running Cocktail on Pilot, then restarting your Mac. If that doesn't get it done, you'll need to look for some other solution.
I upgraded our machines to Mountain Lion, and no, that did not resolve the issue. Several desktop icons (for files) are missing since the upgrade and - lo and behold - they are listed as Adobe Photoshop-created files. Don't get me wrong, I accept Chris' statement that it is an underlying Apple problem.
Thanks all! I've tried Cocktail without any luck and the the drive I store all my PS files is a 40TB XSan but all 6 of our MacPros running 10.7.4 and CS6 have the same problem (one of our artists never upgraded to 10.7.4 and he has no problem seeing prieviews wirh CS6)....frustrating. I don't want to go back to CS 5.5.
Really? Apple's problem? Then why is it only PSCS6 generated icons (ever - in my case. Painter is clunky as all get out and it never does this, in any version. This is a minor nusance, but stillannying)? If the saying" pass the buck" was not invented, software industry would've have invented it. But hey, it's the nature of the beast. I have been guilty in my life more than once(lost count) of always blaming others before myself.
For me to accept Chris' statement he need to explain why PSCS6 is the only application that has this problem, and what did Adobe change in PSCS6 to cause this from PSCS5.
FWIW my "fix" using Cocktail (default Pilot mode) was on the startup drive. (Same with Disk Warrior.) And mine is a standalone Mac Pro 2010 (not part of a local network). There are two other 1TB drives identical to the startup drive in the Mac Pro. One is for Time Machine, the other is a Super Duper clone (from which I run DW). I use the Finder and Open/Save in column view extensively every day, and the icon problem has not returned (over a month now). I also use Default Folder for most navigation in Open/Save, which is probably not relevant but does interact a great deal with Open/Save.
Well… I've just upgraded to CS6 and have this problem.
27" iMac, i7, 2010 model, running 10.6.8.
The icons are missing in list, thumbnail, coverflow... ironically they work fine in column view if this preview arrow is down... the 'listing' is still iconless??
I ran cocktail and rebooted but they are still not working all is fine in CS4 still.
gs
OK, here is what has worked for me...
Delete the .DS_Store file.
You can use terminal or if you are lazy like me, download 'Find Any File.app' then do a search on your mac for .DS
When you find said file on your desktop [probably] right click and delete.
I then reboot with apple, alt, p, r [reset params]
All is now good.
Hope this helps someone else.
gs
Boy, I really started something when I posted my little problem...
I used the deletion of the .DS_Store files and, since I got the final release of PSCS6, haven't had any further problems. I started this discussion when I was using the beta release.
It seems as if the problem persists for some, though. Even with the ML update. I'll post back if I have the problem again, but it hasn't resurfaced for me for months now.
Good luck to all...
Clinton
Clinton,
I am grateful you brought it up - "I am not alone" is always helpful.
As posted earlier, I'll reaffirm that - for ME - the solution was to use Onyx (or similar) to delete all .DS_Store files. The problem still sporadically re-occurs, and yes, only Photoshop CS6 files, but the .DS_Store solution alleviates it.
Was DYP wrote:
"... what did Adobe change in PSCS6 to cause this from PSCS5."
I can tell you a change to icons which nobody from Adobe has mentioned as far as I'm aware.
Ps CS5.1 save results in a multi-resolution icon in the "com.apple.ResourceFork" extended attribute of a file.
Ps CS6 save results in a single-resolution icon in the "com.apple.ResourceFork" extended attribute of a file.
Here is an example of the difference in icons between the versions of Ps. First screenshot is a CS5.1 icon which contains four images, second is a CS6 icon which contains one image.
Chris Cox wrote:
"...the OS is clearly failing to draw thumbnails, and that's not something that Photoshop has any control over."
The icon data of Ps CS6 saved files is different to that of CS5.1 saved files. A change has been made to Ps CS6 which is causing this difference in icons. Either Ps CS6 is writing the icons differently or it is requesting the OS to write the icons differently. If these CS6 icons, but not CS5.1 icons, are related to some intermittent problem when an icon is being read or displayed by the OS, Adobe is still responsible for making a change which lies at the root of this problem of disappearing icons on some systems. A simple solution might be for Ps to go back to creating icons the CS5.1 way.
I'm still having trouble with this, but in testing I'm discovering some very interesting behavior.
If I create a file that has some imagery on the default "Background" layer, it will produce a column viewable thumbnail. When I add an additional layer to the file, the column view thumbnail is broken.
If I take a multi-layer file that has the broken column view thumbnail and flatten it and save it, the column view thumbnail is broken. So something tells me that somehow the file is now "thumbnail broken", but if I copy that imagery and paste it onto the default "Background" layer of a new file, the thumbnail is rendered correctly.
I don't have time to test all the crazy scenarios, but could it be that multiple layers are triggering part of the problem ? — hopefully this might be a valuable clue.
Moglodite,
The thing which you refer to as "column view thumbnail" is not a thumbnail which is attached to a file as an icon. You are referring to the preview of a file which Finder generates when Finder knows how to read particular contents of a file.
Finder does not know how to build composites from layered PSD files, therefore if the file contains no composite then Finder will be unable to provide the preview. If Maximum Compatibility is enabled when saving PSD, then a composite will be embedded in a layered PSD and Finder will use the composite as its preview. (A file containing just a single layer, when that is not the special Background Layer, is considered to be a layered file.) A PSD containing Background Layer only can always be previewed because Finder will use Background as a composite in that special case.
File icons, as used throughout the various Finder display modes, including Cover Flow, are an entirely separate thing from Finder's preview in the right hand column of column mode.
Chris, sorry for asking more of your time, but please clarify.
I manually request OS X 10.6.8 Finder to attach a clipboard image measuring greater than or equal to 512 pixels in at least one dimension to a file as an icon. The system creates and attaches a multi-resolution icon containing 5 images:
512x512, 256x256, 128x128, 32x32, 16x16 pixels.
Ps CS5.1-saved file icons are multi-resolution - they contain 4 images:
Ps CS6-saved file icons are single-resolution:
256x256 pixels.
You are saying that Apple asked Adobe to make a change to the size of icons in preparation for Retina displays. The result of that request doesn't make sense to me. The CS6 icons are no bigger, and they contain fewer resolutions. In what way does that comply with Apple's request?
Being not a very good techie, I called supprt as I could not figure this problem out. In my case( Mountain Lion and CS6) my thumbnails showed in my picture folder, BUT, when I tried to upload a photo to something like facebook, when the picture folder opened, the thumnail was NOT there...just the file name.
What support eventually did with me was to create a new user and open up CS^ inthat. Then, they had me open up CS^ on my own account, holding down the shift key and it worked. Then, they had me reboot and open CS6 the normal way and it worked.
This didn't help me.... I'm desperately trying to find a cure for this strange CS6 preview problem. Funny how I can create a file in PS CS 6 and not see the preview, but if I open that same file in PS CS 5.5 and save it to the same folder, the preview icon magically appears ????
The icons Photoshop CS6 is saving are exactly what Apple asked us to save.
Whether their developer communications are the same as their documentation is another matter.
The icons work perfectly for most users, but somehow MacOS is failing to draw or update icons on some systems. As far as has been determined, this is due to some problem with MacOS itself (since Photoshop always writes the same icon data).
all I can say is that I first called apple about this. They explanined hat since it was no problem in cs5, and since they have no changes to the system, it is obviously a problem at adobe's end. Just reporting.
Then I called adobe and after an hour of working with the rep, making a new user, then going back to old user and starting with the shift key down(not giving all the details as I do not remember them, it was solved. I can provide the case # if interested. Itis clearly an adobe problem.
I would suggest that adobe get in touch with apple and work it out...we really do not care whose problem it is butit should be resolved without having to do what I did.
Chris, you have said numerous times that you are only following Apple's request that you make completely inadequate icons for Retina displays or any other displays in preparation for Retina displays. I believe you! I believe you received certain instructions and have implemented them.
However, common sense screams that here was a communication breakdown or error regarding the icons. Have you or any colleague actually queried Apple about the completely illogical request which runs counter to their software development guidelines? Would you jump of a cliff if someone from Apple requested it, or would you query the request?
Whether their developer communications are as good as their published documentation seems to be at issue here.
Out of curiosity, Chris, have you actually tried writing icons in the way the documentation prescribes, instead of doing it the "Adobe-Apple insider" way?
It seems to me that one investigative approach to this problem might be to provide a patch to someone experiencing the problem to see if feeding OSX icons the documented way vs. the "Adobe knows better" way makes the problem go away. Have you tried that?
-Noel
And there is no way you talked to a developer, so you got Apple's usual "it's everyone else's fault" story from their support line.
The icons work just fine for most people.
They even work fine in some directories, and fail in a few directories for some users.
They work after users clear the OS thumbnail cache.
It is highly unlikely that this is an Adobe problem.
Yes, we checked with Apple, more than a few times. Apple documentation is not always up to date (or complete, or accurate).
But since we can't reproduce any problem with icons/thumbnails - we can't test whether changing the code would help or not. We don't know what is different about the systems of the users having problems. But logically it isn't Photoshop causing the problem, but something about the OS and the thumb/icon cache.
North America
Asia Pacific
