I just downloaded flash cs6 trial and opened a cs5 .fla file in it. I can see it intially (after mac restart) but when i try to play or edit it goes blank. All the keyframes/layers/images are there but nothing is visible on the stage. Thumbnails are visible in library. When i create a new file and import (.png) it is also there but blank.
I really need a FIX!! please help?!
There are two ways I know of to activate the outline mode, one being to click the timeline's small icon(s) for it... those small colored squares following each layer's name (or the one at the top), and the other... Select View -> Preview Mode -> Outlines.
So if clicking the small squares doesn't help, check out the Preview Mode and make sure "Outlines" is NOT selected.
I'm seeing the same thing in full version. I think Flash runs out of memory and just goes blank. It's not a matter of your Preview Mode. I have to quit and restart Flash to see my project when this happens. And as my project is pretty large it happens often. Anyone from Adobe have advice for us?
Not really. In my case I just had to find ways to reduce the FLA file size. I pulled out a bunch of stuff to be loaded from exteranl directories. That seemed to do the trick. Creating robust apps that have thousands of images to support retina screens (and the smaller screens) is a little tricky. Flash gets unstable at a certain point it seems.
I'm back to working. I had uninstalled and reinstalled and that did not help. I was getting a message to uncheck use graphics something or other in performance. Before I had a chance to do that, I was blown out of Cs6 and when I restarted, there was a note that something was changed in my preference file. I'm unsure what the real problem was, but at least it fixed itself.
I have the same issue and have been unable to find any info online. The stage goes black after a few clicks through the timeline. Adobe is no help unless I purchase the product and if I have the problem with the trial, I will most certainly have it when I add the serial number.
Do you remember more details on the alert message that you saw?
Ever since I've had the program, I get the following message everytime I open the program.
I've never acted on it. When I started having the black screen program, (three months later after daily use) I reinstalled the program and it still didn't work. After opening and closing the program a few times, I finally got a message that something in the graphics processor was changed and the program started working again. I guess I'm going to fail again since this message is back up upon start up.
North America
Asia Pacific
