Trying to use the ArrayFindNoCase function, but it doesnt appear to work on multidimensional arrays? i.e. only on single dimensioned array? can anyone confirm this is the case?
I am seeing the same thing. Shame that this post has over 200 views, but no one has an answer.
I am guessing "no" because every example I have Googled has only one dimension. Looks like creating a 'fake' query from scratch is the only way to search a multidimensional recordset.
I think the disconnect you are having here is that you think CFML has multi-dimensional arrays: it doesn't. All it has is arrays that can, themselves, have element values that are also arrays (and so forth).
So array functions don't operate on multi-dimensional arrays because there's no such thing in CFML.
The arrayNew() function is a bit misleading because it claims it creates multidimensional arrays, but it doesn't really. For all intents and purposes arrayNew(3) does the same thing as arrayNew(1): creates an empty array.
If you have this array:
numbers = [
[1,2,3,4],
["tahi","rua","toru","wha"],
["one","two","three","four"]
You cannot use arrayFInd() on the numbers array to find "tahi", but you could use arrayFind() on numbers[1]. This is no help if you don't know which "sub array" the thing you're finding is in.
TBH, there's seldom requirement in business type code for multi-dimensional arrays, and where people do use them, they really ought to be using arrays of structs, or arrays of objects, or similar. What's your data structure here? I ask because one can use structFindValue() to find values in structs irrespective of the complexity of said struct.
Adam
