DOFFNML
Problems With Customization Wizard From 10.1.0 to 10.1.3
May 21, 2012 12:31 PM
I have been working on a custom installation of Acrobat Reader to roll-out to >200 workstations in our field offices.  This project is not my primary domain, but I understand the steps involved. I am running into a roadblock getting from 10.1.0 to 10.1.3.
I understand how to:
*Unpack the .exe
*Create the customization file with the Wizard
*Repack the .exe
However when I reassemble the files, and run the .exe, it keeps me at 10.1.0.  For some reason it doesn't seem to be registering the .msp file.  I have reviewed various threads on this topic, but frankly none of the explanations make sense.
Could someone tell me what I am doing wrong?
Thanks!
    May 21, 2012 1:16 PM   in reply to DOFFNML
    If you're using a bootstrapper workflow rather than an AIP, read the bootstrapper section in the Admin Guide.
    http://www.adobe.com/go/update_details
    If that doesn't help, describe all your steps, the exact point of failure, and any errors you see.
    Ben
    May 21, 2012 2:21 PM   in reply to DOFFNML
    Publish your Setup.ini file in the forum.
    May 25, 2012 12:06 PM   in reply to DOFFNML
    The Admin Guide tells you how to chain installs together and gives an example. Do that.
    Ben
    May 28, 2012 11:38 PM   in reply to DOFFNML
    From what I see from the screenshot (10.1.3 extraction) your exe is corrupt. It should also have the 'AdbeRdrUpd1013.msp' file when you extracted the contents 'AdbeRdr1013_en_US.exe'. You can again try downloading the 10.1.3 exe from the Adobe.com website (http://get.adobe.com/reader/enterprise/). Select the appropriate platform and version of reader (10.1.3 in this case).
    Extract the contents of the exe (AdbeRdr1013_en_US.exe) using the below command line:
    > AdbeRdr1013_en_US.exe -sfx_o"C:\users\vinod\Desktop\10.3Rdr" -sfx_ne
    This will extract the contents in the folder "C:\users\vinod\Desktop\10.3Rdr"
    You can then use the msp 'AdbeRdrUpd1013.msp' to patch your systems. The final setup.ini should look like this:
    [Startup]
    RequireOS=Windows 2000
    RequireMSI=3.0
    RequireIE=6.0.2600.0
    CmdLine= /rps
    [Product]
    msi=AcroRead.msi
    CmdLine=TRANSFORMS="AcroRead.mst"
    PATCH=AdbeRdrUpd1013.msp
    [Windows 2000]
    PlatformID=2
    MajorVersion=5
    ServicePackMajor=4
    [MSI Updater]
    Path=http://ardownload.adobe.com/pub/adobe/reader/win/8.x/8.0/misc/WindowsI nstaller-KB893803-v2-x86.exe
    Let me know, if you find any issues.
